Author Topic: How to statistics the total number of parts?  (Read 19552 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: How to statistics the total number of parts?
« Reply #30 on: November 22, 2011, 09:19:19 AM »
ElpanovEvgeniy,
What are the chances that you'd be willing to put that together in a single PDF, available for download?
in Russian - no problems with quality translation I can not ...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #31 on: November 22, 2011, 09:24:04 AM »
Do you want to translate into English?
nivuahc
« Reply #32 on: November 22, 2011, 09:35:19 AM »
I can take a crack at it, as time permits. Unfortunately time is in short supply for me.
GDF
« Reply #33 on: November 22, 2011, 03:12:42 PM »
Thanks Alan.  I didn't have too many nested blocks, so I just created a simple one.
Works great for nested xrefs...sexy.
Thanks Tim for sharing it.
« Reply #34 on: November 23, 2011, 11:01:35 PM »
I did a copy & paste to HTML then print to DOC format to get a pretty good document.
Although I lost font colors and some of the code was missing LF CRs but I have edited it into a fairly clean document.
I set all code to red & managed to re-color the first two pages of code but there are some 43 pages so I stopped there.
No more time but I can forward the DOC file if you want to take it to the next level. (with Evgeniy's permission of course)
« Reply #35 on: December 04, 2011, 11:59:02 AM »
;;;writie list data  to the text file
(defun WriteDataFile (file_name data_lst / _tostring file)
  (defun _tostring (x / dimzin)
      ((eq 'INT (type x))
       (itoa x)
      ((eq 'REAL (type x))
       (setq dimzin (getvar 'DIMZIN))
       (setvar 'DIMZIN 0)
       (setq x (rtos x 2 8))
       (setvar 'DIMZIN dimzin)
       x
      ((vl-prin1-to-string x))
    ) ;_ 结束cond
  ) ;_ 结束defun
  (if (setq file (open file_name "w"))
      (foreach x data_lst (write-line (_tostring x) file))
      (setq file (close file))
      t
    ) ;_ 结束progn
  ) ;_ 结束if
) ;_ 结束defun
(defun NumInc:WriteConfig ( name lst / _tostring file )
    (defun _tostring ( x / dimzin )
            (   (eq 'INT (type x))
                (itoa x)
            (   (eq 'REAL (type x))
                (setvar 'DIMZIN 0)
                x
            (   (vl-prin1-to-string x)   )
    (if (setq file (open name "w"))
            (foreach x lst (write-line (_tostring x) file))
            t
  :-o
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #36 on: December 04, 2011, 12:20:10 PM »
Why should (setq file (close file))?
Perhaps just enough (close file)...
« Reply #37 on: December 04, 2011, 12:22:10 PM »
Because 'close' always returns nil, so I use it to null the 'file' variable. This way I can check for the 'file' variable in my *error* handler.
xianaihua
« Reply #38 on: December 04, 2011, 08:15:11 PM »
Hi,lee !
sorry!
Forget your copyright :ugly:
This is a good tool!
