Author Topic: (C3D '09) Best Practices: Curb Creation  (Read 6088 times)
« on: January 04, 2010, 02:18:44 PM »
I know we've been over this before but ... what is the best way to create a curb line in C3D that will display correctly and be accurate in terms of the collected field points. Below is an image w/ notes. Hopefully that will help.
thanks
Re: (C3D '09) Best Practices: Curb Creation
« Reply #1 on: January 04, 2010, 02:28:27 PM »
that would depend on level of accuracy you want from your terrain model/figures..
in my classes we practice collecting these items in this manner:
Top Back of Curb
Top Face of Curb
Flow Line
Then Lip of Gutter if there is one....
and you use the point on curve command while collecting them...as explained in the Curve Codes in the Help file.
if I understand your question...
« Reply #2 on: January 04, 2010, 02:32:05 PM »
if you aren't going to do it in the manner above, then one would try to use the Horizontal and Vertical offset commands and 'Template' that curb around....I do not like this function as it assumes ALL those offset distances and elevation changes are CONSTANTS until you tell it to STOP
in short you may need to refine you field practices to collect the data such that it draws what is there...using figures, and to do that most accurately you will need to evolve your process to work with C3D....
« Reply #3 on: January 04, 2010, 02:36:13 PM »
Our field crew doesn't collect the top face of curb so I have to create that line/points.
« Reply #4 on: January 04, 2010, 02:38:30 PM »
"when Hell freezes over" would most likely be the answer. 8-)
« Reply #5 on: January 04, 2010, 02:44:31 PM »
Our field crew NOW collects the top face of curb so I [color=red]DO NOT [/color] have to create that line/points.
They SHOULD be....and that is the method to getting the most out of the Field to Finish Functions...
otherwise one is reduced to MANUALLY creating a 'stepped' offset of that feature line to get ones model  accurate right from the collect data...it's faster and far more accurate than you 'faking' them in no matter how you decide to perform the function....
They (the surveyors) could even include an 'offset' note in the data, however this isn't a true offset, however it would draw that line for you.
have the guys take that shot.....
« Reply #6 on: January 04, 2010, 02:51:39 PM »
I would take them outside and let them collect the data in both fashions...and then process the line work to show them WHY they need to adapt...
in a few of my classes at South East Tech...there is a small concrete drainage feature....basically a flat bottom channel with curbs....in every class they would first shot top back of curb, center, and then top back of curb...this when added to the model creates a Vee Section....
then we go back and collect
Top back, top Face, Flow line, Center if defined,  Flow Line, Top Face, and then Top Back of curb, then we process that and See that the model actually develops a flat channel section with out any MANAUL functions at all....then they ALL change right there that day...because they see why.....
the model is more accurate
it is FASTER in the long run...
you are more productive, and they can anticipate raises and bonuses...
« Reply #7 on: January 04, 2010, 02:52:37 PM »
Without getting into a huge argument over field practices. I cannot tell the crew to take an extra shot. So I have to do this in C3D. Can the software do that? Can I 'fit' a feature line through a series of points to create a curve?
« Reply #8 on: January 04, 2010, 03:00:15 PM »
compromise....have them shoot the Top Face, and NOT the back....
Mark trust me on this one....I've suggested the Best Practice really....
otherwise...one might try this process
build the surface,
add ONLY the Top Back Break figures as Break Lines...
Extract those Objects from the Surface, and then offset them...
I think that would work...as long as we both acknowledge that the ELEVATIONS for them is NOT exact....
I'd rather see you folks perform the survey as accurately as possible instead...given there is no reason to not get the data, and allow the softwae to do what you paid for it to do...
« Reply #9 on: January 04, 2010, 03:16:10 PM »
I believe you Michael, but our field process doesn't revolve around C3D and that ain't gonna happen anytime soon.
build the surface,
I'll give that a try, if I can figure out what you're talking about. *grin*
When I said 'accurate' I meant in terms of the curve not so much the elevation.
sinc
« Reply #10 on: January 04, 2010, 03:17:20 PM »
Michael, your recommended workflow seems idealized to me...
The problems arise along curves.  True, we have things like Multicurves, but (unless Autodesk changed things while I wasn't looking) we can't collect multiple multicurves at once.  And that is further complicated by the nastiness that arises when breaklines cross.
So your recommended workflow of shooting TBC, TFC, FL, and Lip at every station would really start to lead to problems.  Unless you also recommend that field surveyors only collect linework in straight tangent segments, instead of using curve linework commands...?
« Reply #11 on: January 04, 2010, 03:31:51 PM »
No Sinc; curves being the 'special' cases that they are do involve the requisite tedium...of collecting them more in sequence than linear features...however...they can and should be collected in the field
and I'm trying to recall what command, and exact sequence we used to take shots along all the features, and still get C3D to draw the arcs correctly....and I don't have (cant find) any of the students data, nor a collector here to go play with....
I'll try to follow up on this
For Mark,
uh..nevermind...
create the figures...then Export them as AUTOCAD objects.....
import and offset as desired....
« Last Edit: January 04, 2010, 03:35:17 PM by mjfarrell »
sinc
« Reply #12 on: January 04, 2010, 05:33:48 PM »
Basically, it sounds like you are telling me what I already know...  Namely, that despite the improvements in C3D 2010, field linework in C3D is still pretty Mickey Mouse...    :-(
« Reply #13 on: January 04, 2010, 06:12:03 PM »
yes, and no...we did something a little different with one of the curve and feature code and the curves sorted themselves out....
...trust me I am looking for those files, and notes...and or brain cells...
reno
« Reply #14 on: January 04, 2010, 11:38:29 PM »
Am I missing something?  Import these points using the new linework commands in 2010:
79,2399.5198,1488.1455,0.0000,B FL
80,2405.2308,1485.2692,0.0000,B BOC
81,2433.3675,1541.1358,0.0000,BC BOC
82,2427.6564,1544.0122,0.0000,BC FL
83,2431.0347,1554.8388,0.0000,FL
84,2437.5252,1555.2301,0.0000,BOC
85,2435.9611,1571.6579,0.0000,BOC
86,2429.8579,1569.7494,0.0000,FL
87,2425.5674,1578.8360,0.0000,FL
88,2430.4727,1582.9957,0.0000,BOC
89,2419.5738,1593.7520,0.0000,EC BOC
90,2416.0083,1588.4438,0.0000,EC FL
91,2373.3361,1617.1059,0.0000,FL
92,2376.9015,1622.4141,0.0000,BOC
And you get curves with multiple points not taken in sequence.
