Author Topic: Treat me gently please  (Read 4265 times)
« on: December 23, 2009, 11:58:11 PM »
I hope there aren't too many posts like this.
Building a solution
getting
fatal error C1083: Cannot open include file: 'arxHeaders.h':
The ..\inc path is on the  environment variable PATH
The File exists
I've tried both
#include "arxHeaders.h"
and
#include <arxHeaders.h>
any ideas ??
--> Donate to theSwamp<--
Re: Treat me gently please
« Reply #1 on: December 24, 2009, 12:22:42 AM »
Resolved I think
In the Tools->Options Dialog I needed to change the 'Show directories for' combo to 'Include Files"
ie Corresponds to environment variable INCLUDE.
I had them set in the  'Executable Files'
ie Corresponds to environment variable PATH.
« Reply #2 on: December 24, 2009, 12:28:07 AM »
1>TestARX_01 - 0 error(s), 3 warning(s)
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
Now I'm really dangerous  :lol:
owenwengerd
« Reply #3 on: December 24, 2009, 01:05:35 AM »
I recommend against adding the ObjectARX folders to your global settings, as it prevents you from targeting multiple AutoCAD versions. Add them to your project settings instead, so that you can specify different paths for different project configurations. Also, use environment variables:
http://www.manusoft.com/Resources/ARXTips/Main.stm#MSVCEnvironment
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: December 24, 2009, 01:19:16 AM »
You should avoid adding paths globally and add them at the project level. see pics
I use system variable but you can just add the paths directly
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: December 24, 2009, 01:25:03 AM »
oops, do it as sifu Owen does  :laugh:
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: December 24, 2009, 01:25:58 AM »
Welcome to the club  :lol:
Retired
« Reply #7 on: December 24, 2009, 02:01:32 AM »
Thanks Owen,
Thanks Daniel
