Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
[CHALLENGE] Fitted Diagonal Length
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [CHALLENGE] Fitted Diagonal Length (Read 2035 times)
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
on:
December 23, 2009, 09:32:10 PM »
Given :
Container Width
Container Height
Object Thickness
Calculate Object Length which fits into container with corners touching container sides.
enjoy !
source code solution accepted in any language ( even english)
Refer attachment:
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Re: [CHALLENGE] Fitted Diagonal Length
Reply #1 on:
December 24, 2009, 08:18:55 AM »
First I would search and copy someone's code
http://www.theswamp.org/index.php?topic=12578.msg154713#msg154713
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
Mesozoic relic
Seagull
Reply #2 on:
December 24, 2009, 08:22:53 AM »
bugger !!
Logged
Mesozoic relic
Seagull
Reply #3 on:
December 24, 2009, 08:30:31 AM »
My only excuse is :
that was posted before I turned 60, so I can be excused for forgetting about it.
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Reply #4 on:
December 24, 2009, 08:42:12 AM »
I found it while searching for an asin function, it's a good thing too my brain was overloading
Logged
Mesozoic relic
Seagull
Reply #5 on:
December 24, 2009, 08:48:48 AM »
Well, I'm off to bed ... Santa will be here soon
Logged
Global Moderator
Seagull
Reply #6 on:
December 24, 2009, 09:15:52 AM »
I knew I had seen that before. Just could not find it!
My attempt follow my past attempts.
Could not get the triangle relations to work so I fell back on the circle method.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
