Poll
Display center point
0 (0%)
1 (100%)
Total Members Voted: 1
Author Topic: Display center point  (Read 15019 times)
Re: Display center point
« Reply #15 on: December 17, 2009, 02:09:19 AM »
you need to iterate thought the selections set, here is a helper function to help
Acad::ErrorStatus SelectionSetToObjectIds( AcDbObjectIdArray &setIds, ads_name ssname )
  long sslength;
  ads_name ent;
  acedSSLength(ssname,&sslength);
  for (long i = 0; i < sslength; i++)
    AcDbObjectId oId;
    acedSSName(ssname, i, ent);
    if(acdbGetObjectId(oId, ent) == eOk)
      setIds.append(oId);
    else
      return Acad::eNullObjectId;
  return eOk;
Retired
« Reply #16 on: December 17, 2009, 02:15:42 AM »
As you know selection set can contain many objects, once you have converted the selection set to an AcDbObjectIdArray, you need to open each object in the array, cast it to a circle, if it's not null, print your values.
Retired
gnanapaul
« Reply #17 on: December 17, 2009, 02:34:10 AM »
Hi Daniel,
still its showing single circle center point.
I have added the function SelectionSetToObjectIds. How can i call this function?
from where i can call?
« Reply #18 on: December 17, 2009, 02:50:00 AM »
something like
static void ExtTools_test(void)
    OnShowPoints();
  static Acad::ErrorStatus SelectionSetToObjectIds( AcDbObjectIdArray &setIds, ads_name ssname )
    long sslength;
    ads_name ent;
      AcDbObjectId oId;
        setIds.append(oId);
      else
    return eOk;
  static void OnShowPoints()
    ads_name ss;
    if( RTNORM != acedSSGet(_T("P"),NULL,NULL,NULL,ss))
      return;
    AcDbObjectIdArray ids;
    if(SelectionSetToObjectIds(ids,ss) != Acad::eOk)
      return;
    for(size_t i = 0; i < ids.length() ; i++)
      AcDbEntity* pObj = NULL;
      if(acdbOpenObject(pObj,ids[i],AcDb::kForRead) == Acad::eOk)
        AcDbCircle* pCirc = AcDbCircle::cast(pObj);
        if (pCirc !=NULL)
          double dRadius = pCirc->radius();
          AcGePoint3d ptCenter = pCirc->center();
          acutPrintf(_T("\ncenter (%g,%g,%g) radius %g"),
            ptCenter.x,ptCenter.y,ptCenter.z, dRadius);
        pObj->close();
      else
        acutPrintf(_T("\nFailed to open the object."));
    acedSSFree(ss);
Retired
« Reply #19 on: December 17, 2009, 02:55:25 AM »
you may need to remove the _T( ) or add tchar.h
Retired
gnanapaul
« Reply #20 on: December 17, 2009, 03:59:22 AM »
Hi Daniel,
this is also showing error.
void CSampDialog::OnShowPoints()
ads_name ss;
if( RTNORM != acedSSGet("P",NULL,NULL,NULL,ss))
if( RTNORM != acedSSGet(NULL,NULL,NULL,NULL,ss))
acDocManager->unlockDocument(acDocManager->curDocument());
return;
long nEnts;
acedSSLength(ss,&nEnts);
AcDbObjectIdArray entities(nEnts);
acutPrintf("\nFound %d Entities", nEnts);
double pRadius, y_value;
int rc;
ads_name en;
AcGePoint3d pt;
rc = acedEntSel("\nSelect circles: ", en, asDblArray(pt));
if (rc != RTNORM)
acutPrintf("\nNo entity selected...");
return;
AcDbObjectId eId, eId2;
acdbGetObjectId(eId, en);
AcDbObject *pDbObj;
AcDbCircle *pcircle;
AcGePoint3d *pCenter1 = new AcGePoint3d;
acdbOpenObject(pDbObj, eId, AcDb::kForRead);
AcDbCircle* pCircle = AcDbCircle::cast(pDbObj);
if(pCircle == NULL) // means the passed parameter is not an instance of AcDbCircle
return;
if(pCircle == NULL)
return;
AcGePoint3d pCenter = pCircle->center();
y_value = pCenter.y;
pRadius = pCircle->radius();
acutPrintf("Selected object Y value %f\n", y_value);
acutPrintf("Selected object X value %f\n", pCenter);
acedSSFree(ss);
This above code is working fine. and please tell me how to change the above code to show multiple(Selected)  circle's center point....
Really you are great. please help me...
Today is my dead line...
Thanks a lot....
gnanapaul
« Reply #21 on: December 17, 2009, 04:44:21 AM »
Hi Daniel,
Please help me...
« Reply #22 on: December 17, 2009, 05:26:34 AM »
I'm very sorry, your code is so seriously flawed that I recommend you toss what you have and start with the functions I showed you.
Retired
gnanapaul
« Reply #23 on: December 17, 2009, 05:37:10 AM »
Hi Daniel,
I have used your functions only.
But it shows error.
The errors are
error C2065: 'SelectionSetToObjectIds' : undeclared identifier
warning C4018: '<' : signed/unsigned mismatch
error C2373: 'SelectionSetToObjectIds' : redefinition; different type modifiers
Error executing cl.exe.
please help me...
Thanks a lot...
« Reply #24 on: December 17, 2009, 05:40:27 AM »
did you add SelectionSetToObjectIds to your class? or your .h file?
Retired
« Reply #25 on: December 17, 2009, 05:48:01 AM »
if you want it as part of your class
//add this to your CSampDialog.h file
static Acad::ErrorStatus SelectionSetToObjectIds( AcDbObjectIdArray &setIds, ads_name ssname );
//add this to your CSampDialog.cpp
Acad::ErrorStatus CSampDialog::SelectionSetToObjectIds( AcDbObjectIdArray &setIds, ads_name ssname )
    long sslength;
    ads_name ent;
      AcDbObjectId oId;
        setIds.append(oId);
      else
    return eOk;
« Last Edit: December 17, 2009, 05:56:45 AM by Daniel »
Retired
gnanapaul
« Reply #26 on: December 17, 2009, 05:49:13 AM »
yes. I have added like
SelectionSetToObjectIds( AcDbObjectIdArray &setIds, ads_name ssme );a also added
static void ExtTools_test(void);
static void OnShowPoints1() ;
gnanapaul
« Reply #27 on: December 17, 2009, 05:55:01 AM »
It is working good.
Really you are very very good person.
Thanks a lot....
« Reply #28 on: December 17, 2009, 05:59:10 AM »
You are welcome  :-)
Retired
gnanapaul
« Reply #29 on: December 17, 2009, 06:14:37 AM »
Hi Daniel,
I was run correcly at first time.
After that it is not running...
Code in CSampDialog.h
public:
CSampDialog( CWnd* pParent = NULL );
void OnCopy2Excell(const char* pWhat, const AcDbObject* pDbObj);
afx_msg void OnShowPoints();
Code in CSampDialog.cpp
BEGIN_MESSAGE_MAP(CSampDialog, CDialog)
//{{AFX_MSG_MAP(CSampDialog)
ON_WM_CLOSE()
ON_MESSAGE(WM_ACAD_KEEPFOCUS, onAcadKeepFocus)
ON_BN_CLICKED(IDC_BUTTON2, OnShowPoints)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
CSampDialog cmd;
cmd.OnShowPoints();
ads_name ss;
    return;
    if(CSampDialog::SelectionSetToObjectIds(ids,ss) != Acad::eOk)
    return;
if (pCirc !=NULL)
pObj->close();
else
acedSSFree(ss);
    long sslength;
    ads_name ent;
      AcDbObjectId oId;
      if(acdbGetObjectId(oId, ent) == Acad::eOk)
        setIds.append(oId);
      else
    return Acad::eOk;
what is the wrong with this?
Thanks...
