Author Topic: problem in Spline and Polyline construction using MSpace routines!  (Read 4128 times)
web.pawan
Dear members,
   I went through both ARX Programming and General Programming (was C++) boards. Atlast i decided to post this question over here.
   I am having problem in creating complex structures like spline and polyline in C++ due to inability to create verticesList
   I know how to create a single variant from a ads_point. It works.
   I have tried searching various available help from web related to VARIANT (including MSDN) but nowhere(probably i did not get right link)
   i could find out a VARIANT for a list.
   I know how to create spline and polyline using AcDb* routines. I am interested to use MSpace->AddPolyline routines.
VARIANT VerticesList;
#error "help required, do not know how to come up with vertices list"
/* declaration
virtual HRESULT __stdcall AddPolyline (
        /*[in]* / VARIANT VerticesList,
        /*[out,retval]* / struct IAcadPolyline * * pPolyline ) = 0;
hr = test->pMSpace->AddPolyline(/*VARIANT*/ VerticesList, &testPolyLine);
for creating a VARIANT type from ads_point i use following.
void fn_VARIANT_From_ads_point(VARIANT &ptVariant, ads_point pt)
SAFEARRAYBOUND rgsaBound;
rgsaBound.lLbound = 0L;
rgsaBound.cElements = 3;
long i;
SAFEARRAY* pPoint = NULL;
pPoint = SafeArrayCreate(VT_R8, 1, &rgsaBound);
i = 0;
double value = pt[X];
SafeArrayPutElement(pPoint, &i, &value);
i = 1;
value = pt[Y];
i = 2;
value = pt[Z];
ptVariant.vt = VT_ARRAY | VT_R8;
ptVariant.parray = pPoint;
   I have also attached the my compilable problems.cpp file. test_main() should be called to invoke this code.
//    acedRegCmds->addCommand(_T("AsdkComAccess_COMMANDS"), _T("test"), _T("test"), ACRX_CMD_MODAL, test_main);
   here is the complete .cpp file
   .cpp
#if defined(_DEBUG) && !defined(AC_FULL_DEBUG)
#error _DEBUG should not be defined except in internal Adesk debug builds
#endif
#pragma warning( disable : 4278 )
#import "acax17ENU.tlb" no_implementation raw_interfaces_only named_guids
#pragma warning( default : 4278 )
#pragma warning ( disable : 4996 )
#include <rxregsvc.h>
#include <aced.h>
#include <adslib.h>
#include <tchar.h>
#include <acgi.h>
#include <gevec2d.h>
#include <gepnt2d.h>
//copy the point
#define SETPOINT(a,valX,valY,valZ) a[X]=valX; a[Y]=valY; a[Z]=valZ;
typedef struct sTest_s{
//autocade related
    AutoCAD::IAcadDocument *pDoc;
    AutoCAD::IAcadModelSpace *pMSpace;
}sTest_t;
//open and close the doc
HRESULT doc_open(sTest_t *test);
HRESULT doc_close(sTest_t *test);
//variant creation and destroy
void fn_VARIANT_From_ads_point(VARIANT &ptVariant, ads_point pt);
void fn_VARIANT_Destroy(VARIANT ptVariant);
//function that draws polyline and spline
AutoCAD::IAcadLine * test_DrawPolyLine(sTest_t *test);
AutoCAD::IAcadSpline * test_DrawSpline(sTest_t *test);
AutoCAD::IAcadLine * testPolyLine;
HRESULT hr;
acutPrintf(_T("doc_close() exit!"));
ads_point startPoint, endPoint, varPointInBetween1, varPointInBetween2;
SETPOINT(startPoint,10,10,0);
SETPOINT(endPoint,20, 15,0);
SETPOINT(varPointInBetween1,12,13,0);
SETPOINT(varPointInBetween2,13,14,0);
//construct VARIANT type from ads_point
VARIANT startTangent, endTangent;
fn_VARIANT_From_ads_point(startTangent, startPoint);
fn_VARIANT_From_ads_point(endTangent, endPoint);
//how to construct Vertices List VARIANT type for points ads_point startPoint, endPoint, varPointInBetween1, varPointInBetween2;
/* declaration
if(FAILED(hr))
acutPrintf(_T("Failed to draw polyline");
fn_VARIANT_Destroy(VerticesList);
return testPolyLine;
AutoCAD::IAcadLine * test_DrawSpline;
HRESULT hr;
(setq  startPoint (list 10 10))
(setq  endPoint (list 20 15))
(setq  varPointInBetween1 (list 12 13))
(setq  varPointInBetween2 (list 13 14))
(command "spline" startPoint varPointInBetween1 varPointInBetween2 endPoint "" startPoint endPoint)
      virtual HRESULT __stdcall AddSpline (
        /*[in]* / VARIANT PointsArray,
        /*[in]* / VARIANT StartTangent,
        /*[in]* / VARIANT EndTangent,
        /*[out,retval]* / struct IAcadSpline * * pSpline ) = 0;
hr = test->pMSpace->AddSpline(/*VARIANT*/ VerticesList, startTangent, endTangent,&test_DrawSpline);
if(FAILED(hr))
acutPrintf(_T("Failed to draw spline");
fn_VARIANT_Destroy(startTangent);
fn_VARIANT_Destroy(endTangent);
void test_main()
sTest_t *test = (sTest_t*) malloc(sizeof(sTest_t));
doc_open(test);
test_DrawPolyLine(test);
test_DrawSpline(test);
//doc_save_as_DWG(test);
//doc_save_as_PDF(test);
doc_close(test);
    AutoCAD::IAcadApplication *pAcad;
    LPUNKNOWN pUnk = NULL;
HRESULT hr = NOERROR;
ULONG ret;
    LPDISPATCH pAcadDisp = acedGetIDispatch(TRUE);
acutPrintf(_T("doc_open()"));
if(pAcadDisp==NULL)
return E_ABORT;
hr = pAcadDisp->QueryInterface(AutoCAD::IID_IAcadApplication,(void**)&pAcad);
ret = pAcadDisp->Release();
if (FAILED(hr))
return E_ABORT;
hr = pAcad->get_ActiveDocument(&pDoc);
ret = pAcad->Release();
if (FAILED(hr))
return E_ABORT;
hr = pDoc->get_ModelSpace(&pMSpace);
if (FAILED(hr))
return E_ABORT;
test->pDoc = pDoc;
test->pMSpace = pMSpace;
acutPrintf(_T("doc_open() exit!"));
return hr;
ULONG retVal;
acutPrintf(_T("ac_doc_close()"));
hr = test->pDoc->Close();
if (FAILED(hr))
acutPrintf(_T("Error in pDoc->Release"));
else
acutPrintf(_T("pDoc->Release"));
retVal = test->pDoc->Release();
if (retVal!=S_OK)
else
hr = test->pMSpace->Delete();
retVal = test->pMSpace->Release();
if (retVal!=S_OK)
acutPrintf(_T("Error in pMSpace->Release"));
else
acutPrintf(_T("pMSpace->Release"));
return hr;
    long i;
    i = 0;
    i = 1;
value = pt[Y];
    i = 2;
    value = pt[Z];
SafeArrayDestroyData(ptVariant.parray);
SafeArrayDestroy(ptVariant.parray);
   Any help or links is highly appreciated.
Thanks,
P.
P.S I know its quite easy in VB or .NET. I need to know how to do it in C++. Already read following
//http : // www.roblocher.com/whitepapers/oletypes.aspx
It's Alive!
  • Retired
  • AKA Daniel
Re: problem in Spline and Polyline construction using MSpace routines!
« Reply #1 on: December 12, 2009, 10:39:25 AM »
have a look at this pline sample and see if it helps you.   :-)
#include "StdAfx.h"
#include "MyCom.h"
typedef CComPtr<IAcadApplication>    _Application;
typedef CComPtr<IAcadDocument>       _Document;
typedef CComPtr<IAcadDatabase>       _Database;
typedef CComPtr<IAcadModelSpace>     _ModelSpace;
typedef CComPtr<IAcadPolyline>       _PLine;
int MyCOM(const AcGePoint3dArray &arr)
  HRESULT hr = 0;
  CComPtr<IAcadApplication> App = NULL;
  std::vector<double> dbls;
  for(size_t i = 0 ; i < arr.length(); i++){
    dbls.push_back(arr[i].x);
    dbls.push_back(arr[i].y);
    dbls.push_back(arr[i].z);
  SAFEARRAYBOUND rgsabound[1];
  rgsabound[0].lLbound = 0;
  rgsabound[0].cElements = dbls.size();
  LPSAFEARRAY psa = SafeArrayCreate(VT_R8, 1, rgsabound);
  if(psa == NULL){
    acutPrintf(_T("Failed to create array"));
    return -1;
  long index[1];
  for(size_t i = 0 ; i < dbls.size(); i++){
    index[0] = i;
    SafeArrayPutElement(psa,index,&dbls[i]);
  VARIANT ptList;
  ptList.vt = VT_ARRAY | VT_R8;
  ptList.parray = psa;
  if(App == NULL){
    CoInitialize(NULL);
    CComQIPtr<IAcadApplication>
      _app = acedGetIDispatch(TRUE);
    App = _app;
  if (!App){
    acutPrintf(_T("Failed to get Application"));
    return -1;
  _Document Doc;
  hr = App->get_ActiveDocument( &Doc );
  if(FAILED(hr)){
    acutPrintf(_T("Failed to get ActiveDocument %ld"),hr);
    return -1;
  _Database Db;
  hr = Doc->get_Database( &Db );
  if(FAILED(hr)){
    acutPrintf(_T("Failed to get Database %ld"),hr);
    return -1;
  _ModelSpace MSpace;
  hr = Db->get_ModelSpace( &MSpace );
  if(FAILED(hr)){
    acutPrintf(_T("Failed to get Database %ld"), hr);
    return -1;
  _PLine PLine;
  hr = MSpace->AddPolyline( ptList, &PLine );
  if(FAILED(hr)){
    acutPrintf(_T("Failed to add polyline %ld"), hr);
    return -1;
  VariantClear(&ptList);
  CoUninitialize();
  return 0;
« Last Edit: December 12, 2009, 10:44:39 AM by Daniel »
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: December 12, 2009, 10:52:30 AM »
Oh Yea! Welcome to theSwamp   8-)
Retired
web.pawan
« Reply #3 on: December 12, 2009, 12:16:47 PM »
Perfect, i made some changes and it worked!
Happy to be here! :-)
btw, the donate link on your footer doesn't work!
« Reply #4 on: December 12, 2009, 04:31:15 PM »
try this .. http://www.theswamp.org/donate.html
and welcome to theSwamp
--> Donate to theSwamp<--
web.pawan
« Reply #5 on: December 12, 2009, 09:44:16 PM »
 :-) I could find out Donate link at the top,& i did it already!
It was just FYI for all for correction!
« Reply #6 on: December 12, 2009, 09:51:27 PM »
Thank you for the donation.
I'm sure Mark (site administrator) will appreciate it.
