Author Topic: AutoLoading .NET dll's  (Read 14700 times)
Re: AutoLoading .NET dll's
« Reply #15 on: February 22, 2010, 10:17:10 PM »
Nice solution gile.
I loaded the starement from a menubar command.
and added
            (if (wcmatch path
                         (strcat "*\\" (strcase (vl-filename-base f)) "\\*")
                (progn (prompt (strcat "\n DEBUG NETLOADING :\n" path f))
                       (command "_.netLoad" f)
so I got this :
DEBUG NETLOADING :
C:\KDUBPRO\VS2008\AC2010\TESTING\GETSETENV\BIN\DEBUG\GetSetEnv.dll
Thanks Sir, excellent !
