I sent an Autocad 2000 dwg to a consultant who has upgraded to Autocad 2005LT, Part fo the dwg. is misseed( some lines and text) everytime he plots Autocad 2000 dwg. on HP 450.
I even saved as it R14/LT97/ LT98, still missed part of the dwg.I had it printed on 2000, no problem, even a printing shop had no problem., that means dwg is not corrupt.
He called Autodesk and was told that because the security level in 2005LT is set so high, 2000 dwg will not be possible to plot with 2005LT.I find it absurd.Nevr heard this before.
Any ideas how to solve this PROBLEM please.
There are no secrets to success. It is the result of preparation, hard work, learning from failure.
Colin Powell
