If you're using C3D pipes, you'll find that they cannot be queried using Map. The joys of interoperability. If you use QTO you can get the report generated within C3D, then customize the output in a style sheet or take it to Excel if you want to. QTO is a 2010 only feature, but we use it quite a bit now after setting up the Parts List and Point Codes to generate the big ticket quantity items for us.
