Author Topic: rename layouts tabs revisited  (Read 4665 times)
ELOQUINTET
« on: November 09, 2004, 03:52:30 PM »
cab i was just about to use your rename layouts routine when i realized it would rename my template layouts too. i was wondering if it would be possible to incorporate the same sort of ~ prefix omission as you did for plottabs to this routine so my template stay as is?
;;; FUNCTION
;;;  This routine will rename all layout tabs with
;;;   user entered prefix & number or letter suffix
;;; ARGUMENTS
;;; none
;;; USAGE
;;;  re-name-layouts
;;; PLATFORMS
;;;  2000+
;;; AUTHOR
;;; Copyright© 2004 Charles Alan Butler
;;; ab2draft@TampaBay.rr.com
;;; VERSION
;;;  1.0 Oct. 01, 2004
;;;  This software is provided "as is" without express or implied      ;
;;;  warranty.  All implied warranties of fitness for any particular   ;
;;;  purpose and of merchantability
 are hereby disclaimed.             ;
;;;  You are hereby granted permission to use, copy and modify this    ;
;;;  software without charge, provided you do so exclusively for       ;
;;;  your own use or for use by others in your organization in the     ;
;;;  performance of their normal duties, and provided further that     ;
;;;  the above copyright notice appears in all copies and both that    ;
;;;  copyright notice and the limited warranty and restricted rights   ;
;;;  notice appear in all supporting documentation.                    ;
(defun c:rnl (/ tab_name doc cnt x suffix new_list)
  (setq tab_name (getstring t "\nEnter Tab Name prefix (add trailing space): "))
  (cond (tab_name) ((setq tab_name "")))
  (initget "Numbers Letters")
  (setq suffix (getkword "\nSuffix to use? [Numbers or Letters] : <Numbers> "))
  (cond (suffix) ((setq suffix "Numbers")))
  (setq *doc* (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for tab (vla-get-layouts ; get list of layout tabs
    (if (/= (setq tmpname (vla-get-name tab)) "Model") ; omit MODEL space
      (setq new_list (cons (cons (vla-get-taborder tab) tab) new_list))
  ;;  sort list acording to tab order
  (setq new_list (vl-sort new_list
                  '(lambda (e1 e2) (< (car e1) (car e2)))))
  ;;remove the taborder numbers
  (setq new_list (mapcar 'cdr new_list))
  ;; rename the tabs
  (setq cnt (cond ((= suffix "Numbers") 0) (64)))
  (foreach x new_list
    (vla-put-name x
       (strcat tab_name
                   (itoa (setq cnt (1+ cnt))))
                 ((chr (setq cnt (1+ cnt))))
) ; defun
(prompt "\n*-*  Rename Tab layouts Loaded, Enter rnl to run. *-*")
« Reply #1 on: November 09, 2004, 04:26:03 PM »
Like This?
;;; FUNCTION
;;; ARGUMENTS
;;; none
;;; USAGE
;;;  re-name-layouts
;;; PLATFORMS
;;;  2000+
;;; AUTHOR
;;; VERSION
;;;  2.0 Nov. 09, 2004
;;;  purpose and of merchantability are hereby disclaimed.             ;
(defun c:re-name-layouts (/ tab_name doc cnt x suffix new_list excludechr
                            excludetab)
  (setq excludechr "~"
        excludetab T)
  ;; rename the tabs
  (foreach x new_list
    (if (not (and excludetab (vl-string-search excludechr (vla-get-name x))))
      (vla-put-name x
        (strcat tab_name
) ; defun
(prompt "\n*-*  Rename Tab layouts Loaded, Enter re-name-layouts to run. *-*")
« Reply #2 on: November 09, 2004, 04:31:19 PM »
Here is another tab renaming program that Keith gave me. I just made a dialogue for it and added a start number and suffix....don't know if this helps, but here you go.
http://theswamp.org/lilly_pond/ronjonp/renametabs.dvb?nossi=1
to run....appload dvb then type -vbarun renametabs
Ron
ELOQUINTET
« Reply #3 on: November 09, 2004, 04:44:51 PM »
ya know this is gettin reeeeeally anoying just tried the routine and this one doesn't work nor does the other. i am getting that activex message on these too  :evil:  :evil:  :evil:
« Reply #4 on: November 09, 2004, 05:24:15 PM »
The dvb doesn't work either?
« Reply #5 on: November 09, 2004, 05:30:08 PM »
It looks like Dan may have corrupted something that requires a repair re-install
ELOQUINTET
« Reply #6 on: November 10, 2004, 11:05:50 AM »
by the way just tried out your rename layout tweak cab and it works beautifully just what i meant thanks alot buddy. ahhhhhhh exhale
