Do you just want to use the UCS command to rotate your UCS 180 degrees around the x axis?
That still won't allow you to turn lines etc. into polylines.
To do that you'd need to either adjust your UCS to match the object in question, or adjust the objects to all have the same z value
What exactly are you trying to do?
dJE
