Author Topic: Custom keyboard  (Read 6607 times)
hudster
Custom keyboard
« on: November 08, 2004, 05:37:06 AM »
In the distant past I customised my Keyboard so that when i pressed the F4 key it opened/closed the properties dialogue box.
But after being off sick for a week, I came in today and someone has re-set my autocad back to vanila, but no-one will admit to it.
I re-set my saved profile and everything is back, except my custom keyboard commands but I can't remember how I did it.
Anyone have an Idea on how this is done?
MikePerry
Custom keyboard
« Reply #1 on: November 08, 2004, 05:57:18 AM »
Hi
Look at the ***ACCELERATORS section within the Acad.mnu file.
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
ID: TS22496 - Create accelerator keys (keyboard shortcuts) for commands
ID: TS20858 - Assign an AutoLISP® routine to a shortcut key
Have a good one, Mike
hudster
Custom keyboard
« Reply #2 on: November 08, 2004, 07:32:21 AM »
If I have a custom menu, can I add a menu accelerators section to that mnu file?
Dommy2Hotty
Custom keyboard
« Reply #3 on: November 08, 2004, 10:16:26 AM »
Quote from: Hudster
No...accelerators can only be coded in the base menu file...
ML
Custom keyboard
« Reply #4 on: November 08, 2004, 10:27:01 AM »
I don't believe that to be true
This code is straight from my Custom Menu
***ACCELERATORS
[CONTROL+SHIFT+"C"]^C^Cstart;Calc;
[CONTROL+SHIFT+"E"]^C^Cstart;explorer;
Dommy2Hotty
Custom keyboard
« Reply #5 on: November 08, 2004, 10:41:23 AM »
Quote from: ML
***ACCELERATORS
Hmmm...I thought only Toolbars, POPs, and Helpstrings were available in partial menus...
ML
Custom keyboard
« Reply #6 on: November 08, 2004, 07:20:16 PM »
Nope, you have the same flexibilty as The base acad menu. After all, they are both the same file types.
I prefer to use the .mns file. I never modify, load or even save the .mnu file except for the acad.mnu file
hudster
Custom keyboard
« Reply #7 on: November 09, 2004, 04:34:44 AM »
Why wont this work?
//My_Shortcuts_menu_file
***pop 101
**Main
Props [Properties]_properties
//Accelerator Shortcut Keys
***ACCELERATORS
Props ["F4"]
ML
Custom keyboard
« Reply #8 on: November 09, 2004, 06:53:02 AM »
Well, here is a few examples from The acad.mns file ---->
May be you need to try Props [ALT+"F4"]
ID_dbConnect   [CONTROL+"6"]
ID_VBAIDE      [ALT+"F11"]
ML
Custom keyboard
« Reply #9 on: November 09, 2004, 06:57:01 AM »
Hudster,
I think you may need to write it like this -->
[ALT+"F11"]^C^C_properties;
MikePerry
Custom keyboard
« Reply #10 on: November 09, 2004, 07:03:39 AM »
Quote from: Hudster
Why wont this work?
Hi
What is your Menu File called?
Below example assumes Custom.mnu
***MENUGROUP=CUSTOM
***POP101
**MAIN
ID_CusMain  [Main]
ID_CusProps  [Properties]^C^C_.Properties
***ACCELERATORS
ID_CusProps  ["F4"]
The above works, did for me just a minute ago when tested here.
ML
Custom keyboard
« Reply #11 on: November 09, 2004, 07:08:06 AM »
Mine is simply called Custom1, I have had the same Custom menu for like 2.5 years or so but I change it a lot
So,  what part of your menu worked? Or, did you say it is all working now?
Let me know if you need more help
MikePerry
Custom keyboard
« Reply #12 on: November 09, 2004, 07:15:11 AM »
Quote from: ML
Hi Mark
My "Menu Name" question was directed to "Hudster", apologies for any confusion on that front.
The Menu sample I posted should work (worked for me here when I tested).
Cheers, Mike
hudster
Custom keyboard
« Reply #13 on: November 09, 2004, 07:39:31 AM »
I copied your "custom menu" and created a new mnu file.  but when ever I hit F4, it still says configure tablet.
When i did this before it didn't involve menus, it was done some other way.
MikePerry
Custom keyboard
« Reply #14 on: November 09, 2004, 07:46:09 AM »
Quote from: Hudster
Hi
Did you save the menu file as Custom.mnu or Custom.mns ?
My simple offerring will only work if you saved the menu file as one of the above.
