Another PDF question...
...sorry.
I have just been asked to print about 4,000 drawings to .PDF and they have to be split up into a number of different directories. I have BatchPlot working just great, but I would like to be able to set the location of the PDF files ONCE and not again until I SAY.
It seems that right now, my only option is to go through these steps:
1) Close AutoCAD
2) Change the Acrobat Distiller Printing Preferences (check 'Prompt for the PDF Filename)
3) Start AutoCAD
4) Print any old drawing to PDF and select the directory in which I'd like all subsequent files placed.
5) Close AutoCAD
6) Change the Acrobat Distiller Printing Preferences (UNcheck 'Prompt for the PDF Filename)
7) Start BatchPlot and plot away....
Otherwise, I have to sit here and hit Ok for each filename on every plot...which isn't going to happen. OR I have to just print ALL of the drawings to PDF, then sort them out later...which I'd really like to avoid.
Any ideas?
Thanks a lot!
Mike
