Author Topic: Overlay Or Attached Block Reference  (Read 3037 times)
kwarmington
« on: September 03, 2009, 09:20:34 PM »
How can I find out if a block has been overlayed or attached? It doesnt seem to be a property of the block Reference?
Cheers,
Kate
Re: Overlay Or Attached Block Reference
« Reply #1 on: September 03, 2009, 10:15:49 PM »
perhaps something like
if (btr.IsFromExternalReference || btr.IsFromOverlayReference)
   ed.WriteMessage("\nXref: true");
« Reply #2 on: September 03, 2009, 10:22:13 PM »
This may help ...
[Wrapper("AcDbBlockTableRecord")]
public class BlockTableRecord : SymbolTableRecord, IEnumerable
    // Fields
    private static BlockInsertionPointsEventHandler BlockInsertionPoints;
    private static BlockInsertionPointsEventHandler m_blockInsertionPoints;
    private bool m_bSkipDeleted;
    private static int m_nInsPtCount;
    public static string modopt(IsConst) modopt(IsConst) ModelSpace;
    public static string modopt(IsConst) modopt(IsConst) PaperSpace;
    // Events
    public static  event BlockInsertionPointsEventHandler BlockInsertionPoints;
    // Methods
    static BlockTableRecord();
    public BlockTableRecord();
    protected internal BlockTableRecord(IntPtr unmanagedPointer, [MarshalAs(UnmanagedType.U1)] bool autoDelete);
    public void {dtor}();
    public ObjectId AppendEntity(Entity entity);
    public void AssumeOwnershipOf(ObjectIdCollection entitiesToMove);
    protected internal virtual BlockTableRecord Copy();
    private static void DecrementInsPtHandlerCount();
    public ObjectIdCollection GetBlockReferenceIds([MarshalAs(UnmanagedType.U1)] bool directOnly, [MarshalAs(UnmanagedType.U1)] bool forceValidity);
    public BlockTableRecordEnumerator GetEnumerator();
    public ObjectIdCollection GetErasedBlockReferenceIds();
    internal unsafe AcDbBlockTableRecord* GetImpObj();
    public Database GetXrefDatabase([MarshalAs(UnmanagedType.U1)] bool incrementUnresolved);
    IEnumerator IEnumerable.GetEnumerator();
    private static void IncrementInsPtHandlerCount();
    // Properties
    public ObjectId BlockBeginId { get; }
    public ObjectId BlockEndId { get; }
    public BlockScaling BlockScaling { get; set; }
    public string Comments { get; set; }
    public ObjectId DrawOrderTableId { get; }
    public bool Explodable { [return: MarshalAs(UnmanagedType.U1)] get; [param: MarshalAs(UnmanagedType.U1)] set; }
    public bool HasAttributeDefinitions { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool HasPreviewIcon { [return: MarshalAs(UnmanagedType.U1)] get; }
    public BlockTableRecord IncludingErased { get; }
    public bool IsAnonymous { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool IsDynamicBlock { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool IsFromExternalReference { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool IsFromOverlayReference { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool IsLayout { [return: MarshalAs(UnmanagedType.U1)] get; }
    public bool IsUnloaded { [return: MarshalAs(UnmanagedType.U1)] get; [param: MarshalAs(UnmanagedType.U1)] set; }
    public ObjectId LayoutId { get; set; }
    public Point3d Origin { get; set; }
    public string PathName { get; set; }
    public Bitmap PreviewIcon { get; set; }
    protected internal bool SkipDeleted { [return: MarshalAs(UnmanagedType.U1)] get; }
    public UnitsValue Units { get; set; }
    public XrefStatus XrefStatus { get; }
public enum XrefStatus
    NotAnXref,
    Resolved,
    Unloaded,
    Unreferenced,
    FileNotFound,
    Unresolved
kwarmington
« Reply #3 on: September 04, 2009, 12:07:49 AM »
Thanks everyone, that worked a treat :)
« Reply #4 on: September 04, 2009, 12:26:58 AM »
well, I'm not quite everyone Kate,  ... but you're welcome.  :)
« Last Edit: September 04, 2009, 12:42:23 AM by Kerry Brown »
David Hall
  • Automatic Duh Generator
« Reply #5 on: September 04, 2009, 07:41:29 PM »
Nice to see another Aussie here on the swamp.
