We don't have power civil. (When i mentioned using the autocad solution, i meant we use autocad to import the shp)The mdl dialog opened fine, but it errors after hitting run. Maybe because i don't know the File Length, Version, or Shape Type? I'll play around with it though. Thanks. I appreciate you taking time to help!
