your data is now space and comma delimited... get rid of the extra spaces
test these points:
2,10042.7886,5202.6813,96.5967,CP,test,this,note
5,10215.8181,5005.1395,97.6749,CP,I,added,this information
6,10401.1059,5003.1378,98.6763,CP,manually,to the,txt file
Did you try to import the information from the text file I sent earlier? This file is formated the correct way but it only has one column of information. I did try to import the text file using only one column of information and I still couldn't get it to work. So I am guessing that I am doing something else wrong.
No I did not, because you have/had too many delimitters, you have comma space information, the 'extra' space needs to go away...
2000,10444.7852,4822.5276,102.0525,STNSET, this, is, just a test
2001,10437.4203,4797.6784,102.5981,GUT7 B, does, this, actually work
2002,10436.541,4797.8406,102.1363,FL7 B, I, did, get
2003,10434.6841,4797.5401,102.2572,EA7 B, the file, to parse, with only
2004,10437.4466,4801.8939,102.1273,GUT7, one, set, of information
see them spaces? make them gone...
