LOL, well, actually it could me a permissions problem with the printer or the driver installed on the server, have you tried deleting and reinstalling the printer on your machine?
like:
On your machine Go to Printers & Faxes, delete the printer there.
Go to the Run dialog box, enter \\YourPrintServerMachineName
See if there are two separate listings for the printer there or if it is being shared at all.
If there are two separate listings, talk to the ITwit about it.
If there is just one listing, double click on the printer, it should install itself to your machine.
You may have to go a bit more extensive if there is a driver mismatch and they used an older driver as opposed to the one you have installed. You may have to stop and restart your Print Spooler in the services.msc when removing the printer just to get the right port settings over the network too.
