Author Topic: plotting lisp  (Read 21872 times)
ELOQUINTET
plotting lisp
« Reply #30 on: December 08, 2003, 11:55:55 AM »
hey guys i just encountered the problem too when printing an old job which used a different printer. :cry: keep me informed on the updates thanks
dan
plotting lisp
« Reply #31 on: December 08, 2003, 12:45:32 PM »
Daron,
In this code pslayout = LayoutObj
   (setq
      curdwg   (vla-get-ActiveDocument (vlax-get-Acad-Object))
      pslayout (vla-get-Layout (vla-get-PaperSpace curdwg))
 ; Call RefreshPlotDeviceInfo before GetPlotDeviceNames
    (vla-RefreshPlotDeviceInfo pslayout)
    (setq sty (vlax-safearray->list
      (vlax-variant-value (vla-GetPlotStyleTableNames pslayout))
    (setq cfg (vlax-safearray->list
      (vlax-variant-value (vla-Get-PlotConfigurations pslayout))
LayoutObj = #<VLA-OBJECT IAcadLayout 069c7a2c>
plotting lisp
« Reply #32 on: December 10, 2003, 05:05:44 PM »
Well I found the answer,
Stole this code today, :D
It sets all layouts in the drawing to a "page setup" entered by the user.
I'm going to modify to allow some sort of pick list, I guess that would have to be dcl dialog box or
a numbered list displayed on the text screen to pick from.
Anyone have a "Text Screen" pick list routine?
(defun c:psetup (/ lst page res)
 (setq lst (mapcar 'strcase (getPagesetups)))
 (while (not page)
  (setq page (strcase (getstring T "\nspecify pagesetup to apply: ")))
  (if (or (= "" page) (not (member page lst)))
   (progn (princ "\npagesetup not found") (setq page nil))
 (initget "All Current")
  (not
   (setq
    res
    (getkword
     "\n[All/Current]apply pagesestup to which layout(s) : ")))
  (setq res "All")
 (if (= "All" res)
   ; ignore Model Space
  (foreach x (vl-remove "Model" (layoutlist)) (putPagesetup x page))
  ;(foreach x (layoutlist) (putPagesetup x page)) ; Include Model Space
  (putPagesetup (getvar "ctab") page)
 (princ "\nFinished")
; Jason Piercey . May 16th, 2003
; assign a pagesetup to a layout
; [layout] - string, layout name
; [setup] - string, pagesetup to assign
; return: T or nil
(defun putPagesetup (layout setup / layouts plots)
 (defun item-p (collection item)
   (not
    (vl-catch-all-error-p
     (vl-catch-all-apply
      '(lambda () (setq item (vla-item collection item))))))
   item
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-activedocument *acad*)))
  (setq layouts (vla-get-layouts *doc*))
  (setq plots (vla-get-plotconfigurations *doc*))
  (setq layout (item-p layouts layout))
  (setq setup (item-p plots setup))
  (not (vla-copyfrom layout setup))
(defun massoc (key alist / x nlist)
 (foreach x alist
  (if (eq key (car x))
   (setq nlist (cons (cdr x) nlist))
 (reverse nlist)
; Return: list of all pagesetups defined in the current drawing or nil
(defun getPagesetups ()
 (massoc 3 (dictsearch (namedobjdict) "Acad_PlotSettings"))
Re: plotting lisp
« Reply #33 on: February 28, 2006, 03:27:26 PM »
Hey CAB,
Did you ever set up this routine with a dialogue to pick the pagesetups from?
Re: plotting lisp
« Reply #34 on: February 28, 2006, 03:55:29 PM »
If you mean "Import Page Set Up" from another drawing,
then NO. 8-)
Re: plotting lisp
« Reply #35 on: February 28, 2006, 04:00:31 PM »
Not from other drawings. Just a pick list to set all tabs to a certain pagesetup. Kinda like the one in your plottabs routine minus the plotting part.
Re: plotting lisp
« Reply #36 on: February 28, 2006, 06:55:15 PM »
No but I threw this together.
Needs testing. :-)
Code removed, see update in another post.
« Last Edit: February 28, 2006, 10:40:41 PM by CAB »
Re: plotting lisp
« Reply #37 on: February 28, 2006, 07:10:29 PM »
Needs testing. :-)
Seemed to work on my one drawing.  Only one layout, but it copied it over.  The only problem I had was that my titles were too long to see.
Re: plotting lisp
« Reply #38 on: February 28, 2006, 07:13:40 PM »
Needs testing. :-)
bloody amazing ! , your attitude.
Re: plotting lisp
« Reply #39 on: February 28, 2006, 07:21:42 PM »
Updated the DCL file with wider list boxes.
Re: plotting lisp
« Reply #40 on: February 28, 2006, 07:30:02 PM »
Needs testing. :-)
You'll have to clarify, I'm slow at times.
Re: plotting lisp
« Reply #41 on: February 28, 2006, 07:43:06 PM »
expressing my admiration for how helpfull you are. !
Re: plotting lisp
« Reply #42 on: February 28, 2006, 07:54:04 PM »
Well thank you sir.
I love to write code & play tennis.
Neither of which I do that well compared to the talent I see here & there.
But I do it for me so that's ok. So i do it every chance I get. :-)
Re: plotting lisp
« Reply #43 on: February 28, 2006, 10:47:58 PM »
The updated code is Here
Re: plotting lisp
« Reply #44 on: March 01, 2006, 06:07:14 PM »
ron
is that what you were looking for?
