In a very basic form, I use this Code Set Style for a Corridor to only display the featurelines. This has no effect on volumes, sections, etc. You can expand on it to show the different featurelines however you want.
The user will want to assign a NO Display Style (or set up Layers) for the plan view of the links within his corridor assembly that produce the perpendicular lines he does not want.
Quote from: mjfarrell on June 29, 2009, 05:48:13 PMThe user will want to assign a NO Display Style (or set up Layers) for the plan view of the links within his corridor assembly that produce the perpendicular lines he does not want.I fail to see how yours is any different than that which I posted......but instead of specifying each one, and having to add more if more subassemblies are added, I used the <default> of No Show to accomplish the same thing. Works for all corridors, all of the time. Very simple.
