Author Topic: eNotApplicable Exception...  (Read 10990 times)
troga
« on: June 23, 2009, 04:04:40 PM »
Hi ,
I´m struggeling with an exception, in the following situation:
1. ACAD 2009
2. NET command for modifying polylines
3. Adding vertices via AddVertexAt(...) to a newly created polyline, after finishing, I´m using a transaction to write the poly to the DB, after that
    I´m trying to receive a PromptPoint from User to work on with the newly created poly ... after calling ed.GetPoint(...) I get an exception-> eNotApplicable ???
Q: What doe s that  mean ? I tried to lock the doc, changed the CommandFlags but nothing seemed to help... Anyone can help me out ?
NOTE: The exception occurs only on some *.DWG files !! I couldn´t figure out where the difference is .. :-(
Any help is appreciated...  and Thanks in advance.
Glenn R
Re: eNotApplicable Exception...
« Reply #1 on: June 23, 2009, 04:34:14 PM »
Without more information, members would only be guessing.
When posting, to get the maximum chances of people responding, you should provide the following:
1. Code
2. Example data
3. AutoCAD version
4. .NET Framework version
5. OS (including 32bit vs. 64bit)
6. Visual Studio version (or your IDE choice and version)
With no more info than what you've supplied, I would only be guessing; is the GetPoint call inside your transaction for the newly created polyline?
troga
« Reply #2 on: June 23, 2009, 04:48:48 PM »
1. Code
2. Example data
3. AutoCAD version
First, thanks for the fast reply...
1. will apply tomorrow... currently @home
2. ... like no. 1 ...
3. ACAD 2009
4. Vista 32 Bit
5. Visual Studio 2005
6. Yes it´s inside the transaction...
Thanks, I´ll provide the rest of the data tomorrow...
troga
« Reply #3 on: June 23, 2009, 04:56:46 PM »
[code][quote author=troga link=topic=29269.msg348168#msg348168 date=1245790128]
[quote author=Glenn R link=topic=29269.msg348164#msg348164 date=1245789254]
1. Code
2. Example data
3. AutoCAD version
[/quote]
3. ACAD 2009
4. Vista 32 Bit
[/quote]
ok, found a copy of the code :-)
                AcGe.Matrix3d ucs = _Ed.CurrentUserCoordinateSystem;
                AcGe.Point3d origin = new AcGe.Point3d(0, 0, 0);
                AcGe.Vector3d normal = new AcGe.Vector3d(0, 0, 1);
                normal = normal.TransformBy(ucs);
                AcGe.Plane plane = new AcGe.Plane(origin, normal);
                AcDb.Polyline pline = new AcDb.Polyline(points.Count);
                pline.Normal = normal;
                foreach (AcGe.Point3d pt in points)
                    AcGe.Point3d transformedPt = pt.TransformBy(ucs);
                    pline.AddVertexAt(pline.NumberOfVertices, plane.ParameterOf(transformedPt), 0, 0, 0);
                using (AcDb.Transaction tr = _Tm.StartTransaction())
                    AcDb.BlockTable bt = (AcDb.BlockTable)tr.GetObject(_Db.BlockTableId, AcDb.OpenMode.ForRead);
                    AcDb.BlockTableRecord btr = (AcDb.BlockTableRecord)tr.GetObject(bt[AcDb.BlockTableRecord.ModelSpace], AcDb.OpenMode.ForWrite);
                    AcDb.ObjectId plineId = btr.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                    tr.Commit();
                    AcEd.PromptPointOptions opts = new AcEd.PromptPointOptions("\nPlease select direction: ");
                    opts.UseBasePoint = true;
                    opts.BasePoint = points[0];
                    AcEd.PromptPointResult result = _Ed.GetPoint(opts);
                    if (result.Status == AcEd.PromptStatus.OK)
                        tempPt = result.Value;
                    else
                        return;
[/code]
also the message:
utodesk.AutoCAD.Runtime.Exception: eNotApplicable
   bei Autodesk.AutoCAD.Runtime.Interop.ThrowExceptionForErrorStatus(Int32 errorStatus)
   bei AcMgUserInteraction.{ctor}(AcMgUserInteraction* , AcApDocument* pDoc, Boolean prompting)
   bei Autodesk.AutoCAD.EditorInput.Editor.DoPrompt(PromptOptions opt)
   bei Autodesk.AutoCAD.EditorInput.Editor.GetPoint(PromptPointOptions options)
   bei MM_MechanicalSheet.MechanicalSheet.FoilBend()
   bei Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   bei Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   bei Autodesk.AutoCAD.Runtime.CommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
   bei Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
and attached a sample DWG
Glenn R
« Reply #4 on: June 23, 2009, 04:57:46 PM »
Your numbered points are out - you still don't specify .NET Framework version.
Off the top of my head, move the GetPoint call outside the transaction ie. Create poly, add to dbase, commit, then start another transaction for the GetPoint and see how that goes.
Glenn R
« Reply #5 on: June 23, 2009, 05:01:27 PM »
That's not the whole code and your error message to me indicates something else is possibly wrong...
troga
« Reply #6 on: June 23, 2009, 05:09:00 PM »
ok, let´s try again: I use .Net 2.0 and that is  the whole routine:
        [AcRx.CommandMethod("FOILSHEET")]
        public static void FoilBend()
            _isMetal = false;
            AcIn.AcadDocument doc = GetDoc();
            doc.Layers.Add(Configuration._foilsheetLayer);
            showMainFoilOptionsDialog();
            AcGe.Point3d tempPt = new AcGe.Point3d();
            SteelplateJig spj = new SteelplateJig();
            AcGe.Point3dCollection points = spj.Run();
            if (points.Count == 0 || points.Count < 2)
                return;
            else
                    tr.Commit();
                    AcEd.PromptPointOptions opts = new AcEd.PromptPointOptions("\nPlease select the direction: ");
                    else
                        return;
            // sve the point for later usage
            double[] directionPt = tempPt.ToArray();
            double dirAngle = getLinesAngle(points[1].ToArray(), points[0].ToArray(), directionPt);
            _isMid = System.Math.Abs(dirAngle) < .01;
            if (!_isMid)
                _movingLeft = dirAngle < 0;
            if (points != null && points.Count != 0)
                AcIn.Common.AcadPolyline pl = null, polyLeft = null, polyRight = null;
                createOffset(doc, points, directionPt, out pl, out polyLeft, out polyRight, true);
                if (pl == null || polyLeft == null || polyRight == null)
                    return;
                try
                    loadLinetype(doc);
                catch (System.Exception ex)
                    string msg = "Error in loading linetype: " +
                        ex.Message.ToString() + "Stack: " + ex.StackTrace;
                    Debug.Assert(true, msg);
                string lt2 = "ACAD_ISO03W100";
                if (Configuration._lineTypeName != String.Empty)
                    lt2 = Configuration._lineTypeName;
                pl.Layer = Configuration._foilsheetLayer;
                pl.Lineweight = AcIn.Common.ACAD_LWEIGHT.acLnWt100;
                pl.color = AcIn.Common.ACAD_COLOR.acByLayer;
                polyLeft.Linetype = lt2;
                polyLeft.Layer = Configuration._foilsheetLayer;
                polyLeft.ConstantWidth = Configuration._selectedSheetWidth;
                polyLeft.color = AcIn.Common.ACAD_COLOR.acByLayer;
                polyLeft.Lineweight = AcIn.Common.ACAD_LWEIGHT.acLnWt100;
                polyRight.Layer = Configuration._foilsheetLayer;
                polyRight.Lineweight = AcIn.Common.ACAD_LWEIGHT.acLnWt100;
                polyRight.color = AcIn.Common.ACAD_COLOR.acByLayer;
Thanks Glen for your patience  :wink:  !!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #7 on: June 23, 2009, 06:23:36 PM »
Where is this defined
_Ed.
don't have tiime to have a good look, but
Have you tried setting a breakpoint in the debug code and then stepping through to find the error
... or indicate to us the line the error is on when the exception happens.
looks like a COM error to me ..   :|
///kdub
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
« Reply #8 on: June 23, 2009, 06:29:57 PM »
looks like there is a lot more going on that you originally indicated ..
I assume the AcIn.  is Interop ??
where is this coming from (Configuration._foilsheetLayer)
Where is this coming from
SteelplateJig
/// kwb
troga
« Reply #9 on: June 24, 2009, 03:53:30 AM »
SteelplateJig
/// kwb
Hi kdub,
The Configuration._foilsheetLayer is a string, that gets read out of a customer database at this point it is checked and filled correctly.
_Ed is a static property the gets initialized during Initialize().
While debugging and setting the breakpoint, I get a crash at line -> AcEd.PromptPointResult result = _Ed.GetPoint(opts); /*** _Ed. is not invalid ***/
First I got an 'eLock' exception (with the code I provided yesterday), after that I tried to use DocumentLock() and defined a scope around the Transaction block.
After that I´m getting the eNotApplicapable exception at the line mentioned above.
so actually the code looks like this (the critical part):
                try
                    // NOTE: *** after applying the following DocumentLock Block of code, the eLock exception disapeared! ***
                    using (AcAp.DocumentLock l = _Ed.Document.LockDocument())
                            tr.Commit();
                    AcEd.PromptPointResult result = _Ed.GetPoint(opts);  // NOTE: *** <--- here the app crashes...  :realmad:
                    else
                        return;
                catch (AcRx.Exception ex)
                    // shut up all exceptions for now...
Thanks in advance...
troga
« Reply #10 on: June 24, 2009, 03:57:22 AM »
SteelplateJig
/// kwb
Hi kdub,
                try
                            tr.Commit();
                    else
                        return;
forgot to mention....  the SteelPlateJig is a Polyline Jig to draw a kind of 'Ghost Polyline' and to collect coordinates for creating a cross-section of a plastic foil...
Bryco
« Reply #11 on: June 24, 2009, 10:42:11 AM »
swap
It likes to have a point before you tell it to use it
troga
« Reply #12 on: June 24, 2009, 11:50:16 AM »
swap
Thanks I´ll try that...
troga
« Reply #13 on: June 24, 2009, 03:37:08 PM »
Hey Bryco,
your suggestion works!!!
Thanks a lot...  amazing community !
It would be interesting why I got those eLock and eNotAplicable Exceptions, just for understanding, does anybody knows
where to find this kind of information ?
Thanks again.
Troga.
Glenn R
« Reply #14 on: June 25, 2009, 07:30:16 AM »
Good spot Bryco! Have a beer mate.
