Daniel as soon as possible, ...
post some samples when you have them
we're on CUDA for it's proper use:
GRAPHICS, but what I meant was a little out of the box. With these engineers we talked about other uses. In my company we do a lot of environmental calculus for simulations, and the software's we have make a lot of use of CPU's and RAM, actually one of our softwares, developed in Germany, uses GRID computing, and the work that normally would take 15 days of calculus comes out in 3/4 days. The problem is that if the system stuck ...
you won't know it until the end
. We are now thinking and developing our own software that will use Parallel Extensions and CUDA. The idea we came out with was to use the GPU to do some work for us, that is not for the graphic output, OpenGL and Directx have a lot of functions that you can use without getting a graphical output. The same is with WPF, for what I have seen until now, still learning, and maybe I'm wrong, a "paint" method on control in a Windows form makes the whole form drawn, while the same thing done with WPF repaints only the control.
In any case, as soon as I come out with something, you'll see it
