Just having a bit of a faff with my first attempt at WPF and decided I'll try and create a little application to automatically create a drawing register, as a Word Document, simply by selecting a list of drawing files.
Using a REGEX I should be able to select any attribute where the name contains "Drawing Title" +/- a couple of letters with punctuation in between.
Anyway, preamble aside, the part of the task I contemplate having the most difficulty is actually accessing the attributes (attributes = autocad attributes defined within a block). I'll need to get at these without opening up a drawing......if that's possible
Are there any swampers experienced or resourceful enough to give me some clues?
