How to use "AutoCAD Dockable Container" in C#?
reference:
http://www.jrl-e.com/index.htmWho can tell me?
Below is an example of a VB implemented IRetrieveDockableContainer:
‘ Global variable so the interface can be used at a later time if needed.
Dim dockContainer As AcadDockableContainer
Implements IRetrieveDockableContainer
Private Sub IRetrieveDockableContainer_SetDockContainer(ByVal newVal As IAcadDockableContainer)
‘ Keep this interface around by assigning it to a global variable.
Set dockContainer = newVal
‘ Allow docking only on the left and right sides of AutoCAD
dockContainer.EnableDockPositions = acDockLeft + acDockRight
‘ We want the window to appear as a floating window the very first time.
‘ The size of the floating window is specified below.
Dim rect(0 To 3) As Integer
rect(0) = 50 ' left
rect(1) = 50 ' top
rect(2) = 300 ' right
rect(3) = 300 ' bottom
dockContainer.SetPreferredDockPosition acFloating, rect
End Sub
How to write these in c#?
