Author Topic: How to use ARX call Csharp's form  (Read 2434 times)
ahlzl
« on: May 21, 2009, 08:07:05 PM »
Hi all friend:
I want use ARX call Csharp's form, call C#'s dll file and make *.arx file(not *.dll file), but fail, wait your help, thanks!
MickD
  • (x-in)->[process]->(y-out)
Re: How to use ARX call Csharp's form
« Reply #1 on: May 21, 2009, 08:11:25 PM »
Although you can make .net code in C++ I don't think you can mix and match as you want to do without some heavey duty coding.
Mind you, you can use winforms in C++, maybe that's a better way to go?
Forth is like the Tao: it is a Way, and is realized when followed.
Its fragility is its strength; its simplicity is its direction - Michael Ham
"First, solve the problem. Then, write the code." ó John Johnson
ahlzl
« Reply #2 on: May 21, 2009, 08:24:02 PM »
MFC is vrey trouble, C#'s form is easy.so I want use ARX call Csharp's form.
MickD
« Reply #3 on: May 21, 2009, 08:39:15 PM »
No MFC required, have a look here -> http://www.functionx.com/vcnet/index.htm
What you may have to do is write a mixed/managed dll to netload into acad instead of an arx but you still have all of the arx functionality at your fingertips, might be a better way to go, if not why not just use C# for all of your code, there's very little not exposed to .net these days.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: May 21, 2009, 09:42:27 PM »
Yeah, the learning curve with MFC is a little steep, Iím trying to claw my way up it now.
Iím actually starting to like MFC  :laugh:
If you want to use forms with Arx, just make a mixed mode application, or just use C# (as Mick says).
Retired
