Author Topic: Traverse PC  (Read 5976 times)
Re: Traverse PC
« Reply #15 on: May 19, 2009, 11:27:51 AM »
Worst case scenario it appears they support a DXF export, which is/was a standard one could rely on.
Matt__W
  • I like my water diluted.
Re: Traverse PC
« Reply #16 on: May 19, 2009, 11:38:14 AM »
 :whistle:
Autodesk Expert Elite
craigr
Re: Traverse PC
« Reply #17 on: May 19, 2009, 11:44:24 AM »
If it was my post, I REALLY didn't mean to hijack this thread. (I apologize)
I was just curious about dwgs being the same from two different prgs.
craigr
Matt__W
Re: Traverse PC
« Reply #18 on: May 19, 2009, 11:50:03 AM »
There's a big difference between being the same and being compatible.  TPC claims to be able to read/write DWG/DGN files.
Is there anyone here who is familiar with this software? How compatible is it with AutoCAD? Even better, can someone post a sample topo drawing that is created using this software?
As for the original post, I think what they're looking for is, when a DWG is created from TPC, are the contours at their actual elevation or are they sitting at 0 but with a label that says (for example) 625'?
Dinosaur
Re: Traverse PC
« Reply #19 on: May 19, 2009, 11:56:50 AM »
Would you expect to be able to open a drawing created in r2007 with r2008 without any issues?  I had a Final Plat fully annotated in C3D 2007 that was put on hold until an adjoining phase of the development was completed.  While this phase was being completed, our office upgraded to C3D 2008 to take advantage of features that were either new or fixed and an overall increase in stability.  When it was time to finish off the Final Plat of the earlier phase, the base drawing had been converted to 2008 and at least 2 of every 3 line labels were missing and none of the curve labels had survived in usable format.
It is quite common for large residential development projects to span several years, and often the same basic information is being used in planning stages for one phase, early design in another, finishing the approval process for a different phase while being staked for construction for a phase nearing completion.
With the current release cycle and having basic elements not able to carry forward much less back to previous releases, there is a significant interoperability problem with at least this vertical application.
sinc
Re: Traverse PC
« Reply #20 on: May 19, 2009, 12:03:36 PM »
This must have something to do with something you were doing, because we didn't have that problem.  There were some issues converting 2007 drawings to 2008, but we didn't have that problem.
Dinosaur
Re: Traverse PC
« Reply #21 on: May 19, 2009, 12:17:49 PM »
I recall much of the issue surrounded leaders and layers.  No leaders survived even on the line labels and certain labels esp. on curves translated onto odd layers.  These were all just general line and curve labels with all elements supposed to be on a single layer for plat annotation only.
Re: Traverse PC
« Reply #22 on: May 19, 2009, 12:49:36 PM »
Further checking reveals that this product does NOT write an XML file.
At this juncture it is adviced that they send you at least two(2) sample files so that you may discover what conversion issues you will need to overcome if any.
Re: Traverse PC
« Reply #23 on: May 19, 2009, 12:53:47 PM »
craigr
Yours was a legitimate question framed from curiosity.  No harm no foul.
