Author Topic: I WANT TO SHOW ONLY PART OF FILENAME IN A FIELD  (Read 6399 times)
BETO_45
« on: May 12, 2009, 03:23:09 PM »
I AM HAVING A PROBLEM. I AM PUTTING IN A FIELD FOR THE FILE NAME. THE PROBLEM IS I ONLY WANT TO SHOW PART OF THE FILE NAME . I HAVE TAKEN OFF THE THE FILE EXTENSION. SO RIGHT NOW IT READS 2061-TS01 , BUT I ONLY WANT TO SHOW
TS-01. RIGHT NOW I AM USING WIPEOUT TO NOT SHOW THE FIRST PART OF THE FIELD . I WAS WONDERING IF THERE IS A CLEANER WAY OF DOING THIS
BETO_45
Re: I WANT TO SHOW ONLY PART OF FILENAME IN A FIELD
« Reply #1 on: May 12, 2009, 03:44:44 PM »
RIGHT NOW I HAVE THIS CODE
%<\AcVar Filename \f "%fn2">%,
BUT I WAS WONDERING IF I COULD ADD TO IT TO SAY MINUS HOW EVER MANY CHARACTERS IN THE BEGINNING OR ONLY SHOW A CERTAIN AMOUNT AT THE END
Shinyhead
« Reply #2 on: May 12, 2009, 03:52:59 PM »
OK, there may be other ways to do it, but this works
%<\AcDiesel $(substr,$(getvar,dwgname),1, 4)>%
the last two numbers (the 1 & 4) determine where to start (character 1 of the name in this case) and how many characters to show (4 characters in this case).
Might work for you.
Matt__W
  • I like my water diluted.
« Reply #3 on: May 12, 2009, 03:58:09 PM »
 :roll:
Autodesk Expert Elite
BETO_45
« Reply #4 on: May 12, 2009, 04:19:17 PM »
WORKS LIKE A DREAM THANKS
Shinyhead
« Reply #5 on: May 12, 2009, 04:20:36 PM »
NO PROBLEM    :lol:
Matt__W
« Reply #6 on: May 12, 2009, 04:21:48 PM »
 :whistle:
