I have a drawing with numerous anonymous blocks with nested entities.
If I explode the blocks the drawing size shoots up to over 2 meg, and bearing in mind this is to be used as an Xref, file size is important.
I've tried to refedit the block to remove the nested layers and linetypes, but as it's anonymous, it won't let me.
How can I rename these blocks away from the "*U001" to a format I can work with?
