Author Topic: Get objectid from handle string  (Read 15633 times)
MickD
  • (x-in)->[process]->(y-out)
« on: May 03, 2009, 07:14:54 PM »
Hi All,
I'm having a bit a brain fart trying to get an object id from a handle string that I pull in from a text file the string is fine, just want to convert to an object id so I can do some work on the entities, any tips?
here's what I'm using so far but I'm getting rubbish.
               // convert the string to a valid handle:
ads_name name;
acdbHandEnt(wchandle, name);
// get the object id from the name entity:
AcDbObjectId id;
acdbGetObjectId(id, name);
acutPrintf(_T("id: %ld\n"), name[0]);
thanks,
Mick.
Forth is like the Tao: it is a Way, and is realized when followed.
Its fragility is its strength; its simplicity is its direction - Michael Ham
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
Spike Wilbury
Re: Get objectid from handle string
« Reply #1 on: May 03, 2009, 08:37:03 PM »
Hi All,
ads_name name;
AcDbObjectId id;
thanks,
Mick.
Mick,
It is just a minor stuff:
acutPrintf(_T("id: %ld\n"), id);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: May 03, 2009, 08:48:17 PM »
you can also use  AcDbHandle and AcDbDatabase::getAcDbObjectId()
Retired
MickD
« Reply #3 on: May 03, 2009, 08:49:50 PM »
Thanks Luis, I did see that, was just trying to see what was in the ads_name as I think it's supposed to be the objectid??
I'm not sure that acdbHandEnt is quite what I need but I can't spot anything else at the moment.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: May 03, 2009, 08:52:35 PM »
is the same as
acutPrintf(_T("id: %ld\n"), (long)(AcDbStub*)id);
Retired
MickD
« Reply #5 on: May 03, 2009, 08:55:09 PM »
Thanks Daniel, I'll take a look at that now.
Spike Wilbury
« Reply #6 on: May 03, 2009, 09:01:09 PM »
Yes.
MickD
« Reply #7 on: May 03, 2009, 09:21:03 PM »
Here's the code I'm using if someone wants to have a play.
void test()
AcDbObjectIdArray ids;
char handle[80];
AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
FILE* fp = fopen("C:\\test\\handles.txt","r");
while(fgets(handle,80,fp))
ACHAR uStr[80]; // storage for our unicode converted string
size_t origsize = strlen(handle) + 1;
const size_t newsize = 100;
size_t convertedChars = 0;
wchar_t wchandle[newsize];
mbstowcs_s(&convertedChars, wchandle, origsize, handle, _TRUNCATE);
acutPrintf(_T("%s"), wchandle); // <---------works fine.
AcDbObjectId id;
AcDbHandle h = wchandle;
pDb->getAcDbObjectId(id, false, h);
fclose(fp);
and I write the handles out to a text file in vba using this -
Public Sub testhandles()
Dim SS1 As AcadSelectionSet
Dim Ent As AcadEntity
Dim i As Integer
Dim FilterType1(0 To 0) As Integer
Dim FilterData1(0 To 0) As Variant
FilterType1(0) = 0
FilterData1(0) = "3DSOLID"
Set SS1 = vbdPowerSet("SS1") 'let me know if you need this.
SS1.SelectOnScreen FilterType1, FilterData1
Dim file As String
Dim fileno As Integer
fileno = FreeFile
Open "C:\test\handles.txt" For Output As #fileno
If SS1.Count <> 0 Then
       For Each Ent In SS1
       Print #fileno, Ent.Handle
       Debug.Print Ent.ObjectID
       Next
End If
just create the directory or change the paths to suit as required.
thanks.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: May 03, 2009, 09:49:50 PM »
try this
  static void ArxDbg_doit(void)
    TCHAR handle[80];
    FILE* fp = _tfopen(_T("C:/test/handles.txt"),_T("r"));
    while(_fgetts(handle,80,fp))
      CString cstrHandle = handle;
      cstrHandle.Trim();
      AcDbObjectId id;
      AcDbHandle acDbHandle(cstrHandle);
      pDb->getAcDbObjectId(id, false, acDbHandle);
      if(!id.isNull())
        ids.append(id);
    fclose(fp);
    for (int i = 0 ; i < ids.length() ; i++)
      acutPrintf(_T("id: %ld\n"), (long)(AcDbStub*)ids[i]);
« Last Edit: May 03, 2009, 09:58:56 PM by Daniel »
Retired
MickD
« Reply #9 on: May 03, 2009, 10:22:04 PM »
Thanks Daniel,
I'll give it a go, I was trying to avoid MFC if I could and I didn't create the project with MFC support and I can't get CString to work, what project settings do I need to bring MFC back in??
I've had a bit of a look but nothing popped out at me.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: May 03, 2009, 11:46:28 PM »
or this
#define stringlen 80
    TCHAR inhandle[stringlen];
    while(_fgetts(inhandle,80,fp))
      TCHAR outhandle[stringlen];
      for (int i = 0, j = 0 ; i < stringlen  ; i++)
        if(47 < inhandle[i] && inhandle[i] < 58 ||
           64 < inhandle[i] && inhandle[i] < 71 ||
           96 < inhandle[i] && inhandle[i] < 103 )
          outhandle[j++] = inhandle[i];
        outhandle[j] = '\0';
      AcDbObjectId id;
      AcDbHandle acDbHandle(outhandle);
      if(!id.isNull())
        ids.append(id);
    fclose(fp);
Retired
MickD
« Reply #11 on: May 04, 2009, 12:17:01 AM »
You da man Dan!   :kewl:
A bit of gynastics there but the result worked perfect, thanks a bunch. :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: May 04, 2009, 12:31:40 AM »
My pleasure, I needed a little bit of exercise this morning  :laugh:
Retired
MickD
« Reply #13 on: August 10, 2016, 11:14:53 PM »
I've just fixed a subtle bug that has been a sporadic problem over the years. It seems that creating a handle from the string value is not reliable, to fix it I convert the string to an int (which is really what a hex value is anyway) and all is good in the world again :)
Here's the change:
Code - C++: [Select]
  1. #define stringlen 80
  2. static void ArxDbg_doit(void)
  3. {
  4.         AcDbObjectIdArray ids;
  5.         TCHAR inhandle[stringlen];
  6.         AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
  7.         FILE* fp = _tfopen(_T("C:/test/handles.txt"), _T("r"));
  8.
  9.         while (_fgetts(inhandle, 80, fp))
  10.         {
  11.                 Adesk::UInt64 hexnum = std::stoi(inhandle, 0, 16);//<<-------ADDED
  12.                 AcDbHandle acDbHandle(hexnum);
  13.
  14.                 AcDbObjectId id;
  15.                 ErrorStatus es = pDb->getAcDbObjectId(id, false, acDbHandle);
  16.                 if (es == eOk)
  17.                 {
  18.                         ids.append(id);
  19.                 }
  20.                 if(es == eUnknownHandle){
  21.                         acutPrintf(_T("Error: eUnkownHandle"));
  22.                 }
  23.         }
  24.         fclose(fp);
  25.
  26.     for (int i = 0 ; i < ids.length() ; i++)
  27.     {
  28.       acutPrintf(_T("id: %ld\n"), (long)(AcDbStub*)ids[i]);
  29.     }
  30.   }
  31.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: August 15, 2016, 08:11:24 AM »
***runs off to review all posted code***
Retired
