Job: - CanceledJob ID: 1Sheet set name: Date and time started: 23/04/2009 12:30:09Date and time completed: 23/04/2009 12:30:14UserID: CdarmProfile ID: Total sheets: 1Sheets plotted: 1Number of errors: 1Number of warnings: 0 Sheet: MIA GROUND FLOOR-Model - Plotted with Error(s)File: G:\Medairco\Technical Dept\Contracts\2008\C2091 - MIA\Drawings\CHRIS DRAWINGS\MIA As Fitted Drawings\MIA GROUND FLOOR.dwgCategory name: Page setup: Device name: DWG To PDF.pc3 - plotted to filePlot file path: C:\Documents and Settings\Cdarm\Desktop\MIA GROUND FLOOR.pdfPaper size: ISO full bleed A1 (594.00 x 841.00 MM)ERROR: Internal Error: Null Pointer
Hey! I've got an idea. Instead of using our time to fix the bugs, let's totally revamp the way our software looks. Hmmm... but how? Oh, I know!! Let's make it look like Microsoft Office! Let's just "borrow" their ideas and call it our own!
Kate, is the new one broken? I ask b/c the 08 version was broken, and the work around was to bring the 07 version forward
Quote from: CmdrDuh on April 23, 2009, 01:34:02 PMKate, is the new one broken? I ask b/c the 08 version was broken, and the work around was to bring the 07 version forwardNo, using an old PC3 is what causes the problem.
Quote from: Kate M on April 23, 2009, 02:16:55 PMQuote from: CmdrDuh on April 23, 2009, 01:34:02 PMKate, is the new one broken? I ask b/c the 08 version was broken, and the work around was to bring the 07 version forwardNo, using an old PC3 is what causes the problem.UH OHHH
Quote from: krushert on April 23, 2009, 02:33:23 PMQuote from: Kate M on April 23, 2009, 02:16:55 PMQuote from: CmdrDuh on April 23, 2009, 01:34:02 PMKate, is the new one broken? I ask b/c the 08 version was broken, and the work around was to bring the 07 version forwardNo, using an old PC3 is what causes the problem.UH OHHH What? Is it really THAT troublesome to create new ones?
Quote from: M-dub on April 23, 2009, 02:34:29 PMQuote from: krushert on April 23, 2009, 02:33:23 PMQuote from: Kate M on April 23, 2009, 02:16:55 PMQuote from: CmdrDuh on April 23, 2009, 01:34:02 PMKate, is the new one broken? I ask b/c the 08 version was broken, and the work around was to bring the 07 version forwardNo, using an old PC3 is what causes the problem.UH OHHH What? Is it really THAT troublesome to create new ones?No Cotton but it felt good in saying that and you like it.
back to the topic...i clicked on export from the big 'A' in the corner, i tried it from the ribbon and also used the dwg to pdf plotter but nothing worked. oh and even from the publish command. then i did like always and used cutepdfwriter... (i like that little piece of software )
