Author Topic: Nested XOPEN  (Read 2223 times)
MDONUT12
Nested XOPEN
« on: April 11, 2009, 01:34:23 PM »
Hi everyone,
I have this code I've been using for a couple years that worked fine inside VBA. Now inside AutoCAD 2010, I'm trying to port all my code to .net. Its mainly still using COM for everything as you can see. My main issue is the code opens the xref i selected, however it switches back to the original drawing. Then when it runs the zoom operation, its running in the original drawing and not the xref host drawing. I'm trying to keep it on xref host file so the zoom can take effect on that drawing not, the original drawing.
The idea is to have the user issue the command select a line inside an xref, then open the xref, then zoom to that object. (Think for a civil plan with thousands of similar lines, you can get right to the one you picked regardless of where the xref host drawing was saved at in model space).
Here is where I'm at, thanks for any help!!
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class vbstudentClass
    <CommandMethod("NXOPEN")> _
 Public Sub NewCmd1()
        Dim ThisDrawing As AcadDocument
        ThisDrawing = DocumentManager.MdiActiveDocument.AcadDocument
        Dim MyApp As AcadApplication
        MyApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
        ' myapp = inter
        Dim PickPoint As Object
        Dim objEntity As AcadEntity
        Dim Object2 As AcadEntity
        Dim PickedPoint As Object, TransMatrix As Object, ContextData As Object
        ThisDrawing.Utility.GetSubEntity(Object2, PickedPoint, TransMatrix, ContextData, "Select Object in Xref to Open to: ")
        Dim X As AcadExternalReference
        X = ThisDrawing.ObjectIdToObject(ContextData(0))
        Debug.Print(X.Path)
        Dim DWGpath As String
        DWGpath = X.Path
        Dim Mytrue As Boolean
        Dim Fullpath As String
        Dim MyDWG As AcadDocument
        Mytrue = True
        Dim magnification As Double
        Dim zoomScale As Double
        Dim min, max
        Try
            If Mytrue = True Then
                Mytrue = False
                Fullpath = ThisDrawing.Path & "\" & DWGpath
                MyApp.Application.Documents.Open(X.Path)
                magnification = 10
                Object2.GetBoundingBox(min, max)
                MyApp.ZoomWindow(min, max)
                MyApp.Application.ZoomExtents()
                If MyApp.Application.ActiveDocument.ReadOnly = True Then
                    MsgBox("This file is read only")
                    Exit Sub
                End If
                zoomScale = 0.9
                MyApp.ZoomScaled(zoomScale, AcZoomScaleType.acZoomScaledRelative)
                Exit Sub
            End If
            'Else
        Catch ex As Exception
            MyDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(X.Path, False)
        End Try
    End Sub
End Class
Re: Nested XOPEN
« Reply #1 on: April 14, 2009, 03:06:53 PM »
I don't know about VB .Net, but with C# you have CommandMethod flags, and one of them is Session.  What the Session flag does is allow the command to active within the whole session of acad instead of just the calling document, which seems to be the case here.  Adding the Session flag may be all you need to do do have it stay within the current document.  If not, then just make a check to see if the current document is the one you opened or is the one the routine was called from, and if it's not the one you want, change it before you issue the Zoom method.
