Author Topic: lambda  (Read 2711 times)
curmudgeon
lambda
« on: March 31, 2009, 02:26:10 PM »
I have
(setq lst (vl-sort lst (function (lambda (a b) (< (car a) (car b))))))which sorts a list for me, the list is of a form
(("101" "3E16F") ("102" "3E0C3") ("103" "3DFFB") ("104" "3DFD9") ("105" "3DFA8") ("106" "3DFCA")....)text content, entity handle. I guess I should call this an association list because the text is the (1 . "text") from one entity, and the other is the (5. "handle") from a lwpolyline, which might imply that I am learning something.
I look into the help files, and searched the board(s). I look for references to lambda, and cross referenced function,  ' and list, mapcar and apply. Lambda is defining an anonymous function  (< (car a) (car b)), and passing the result through function, which is the same as ', but allows for optimization, which passes that result to vl-sort to use on the list lst.
I typed it myself, and it still is at least 50% gibberish to me.
Would someone explain in their own words what is happening here, please? I am wanting, at this point in the program, to change the nature of the list sorted to include a points list for the polyline, because this would be the easiest time to get it, rather than grabbing the handle and (entget (handent)).
I am guessing there is a way. Maybe
(("101" "3E16F" ((x y)(x y) (x y)....)("102" "3E0C3")((x1 y1)(x2 y2]) (x3 y3)....)... )
or
(("101" ("3E16F" (x y)(x y) (x y)....)("102" "3E0C3")((x1 y1)(x2 y2) (x3 y3)....)... )
or even
(("101" '("3E16F" (x y)(x y) (x y)....)("102" "3E0C3")((x1 y1)(x2 y2) (x3 y3)....)... )
Understanding is what I am after.
thanks,
roy
Never express yourself more clearly than you are able to think.
Re: lambda
« Reply #1 on: March 31, 2009, 02:53:38 PM »
Before going on a superfluous winded discussion ... does this clarify?
(defun foo ( a b ) (< (car a) (car b)))
(vl-sort lst 'foo)
\|// Set goal. Experiment tirelessly until
|Oo| practice has become expertise.  Loop.
|- | LinkedIn | Dropbox
Re: lambda
« Reply #2 on: March 31, 2009, 02:55:41 PM »
curmudgeon
Re: lambda
« Reply #3 on: March 31, 2009, 03:23:03 PM »
that helped very much.
I'll try to keep the winds down.
Re: lambda
« Reply #4 on: March 31, 2009, 03:34:16 PM »
Glad it helped curmudgeon, let us know if you need clarity on anything :).
PS: The wind reference was about me: I can go off on long winded explanations only to find out I went down some road no one cares about; just trying to avoid the resulting .
Re: lambda
« Reply #5 on: March 31, 2009, 03:38:46 PM »
I believe Stig Madsen did an explanation on mapcar/lambda as well but I can't seem to find. :(
Spike Wilbury
Re: lambda
« Reply #6 on: March 31, 2009, 03:54:19 PM »
I recall one by Vladimir Nesterovsky - it must be on the web (still)....from many moons ago
Re: lambda
« Reply #7 on: March 31, 2009, 11:17:37 PM »
Maybe this?
http://www.theswamp.org/index.php?topic=340.0
PS Brings back happy memories. Those were my early days just learning the language.  :-)
« Last Edit: March 31, 2009, 11:25:45 PM by CAB »
I've reached the age where the happy hour is a nap. ()
John Kaul (Se7en)
Re: lambda
« Reply #8 on: April 01, 2009, 08:56:36 AM »
Vladimir's page is still up. [ http://vnestr.tripod.com/ ]
His explanation.
[ http://members.tripod.com/~vnestr/mapcar.txt ]
Re: lambda
« Reply #9 on: April 01, 2009, 09:26:34 AM »
I miss Vladimir, he was like Tony Lite: all the intellect, none of the attitude.
John Kaul (Se7en)
Re: lambda
« Reply #10 on: April 01, 2009, 09:49:01 AM »
I learned a lot from his web pages. Of course i learn a lot from everyone everywhere too.
I talked to him via email a couple of times and i tried to get him to take part in the challenges here (back when we were having them on a regular basis) but he never did show up. Last i heard he was big on Haskell.
TimSpangler
  • CAD Naked!!
Re: lambda
« Reply #11 on: April 01, 2009, 12:00:11 PM »
 :-D
ACA 2015 - Windows 7 Pro
All Comments and Content by TimSpangler, Copyright 2016
hermanm
Re: lambda
« Reply #12 on: April 02, 2009, 11:24:37 AM »
Perhaps this will help.
Only comment:
might want to use (function (lambda <yada yada>)) instead of quote
Thx to LE for pointing this out many moons ago
If you don't know where you are going, you might not get there.
  - L.P. Berra
Spike Wilbury
Re: lambda
« Reply #13 on: April 02, 2009, 11:34:23 AM »
Only comment:
Are you Herman?.... from the old happy days at the autolisp customization ng from adesk, if so I'm glad to see you around here!!!!!! (I mean read you) - have been a long time, Sir. :)
Luis Esquivel.
Re: lambda
« Reply #14 on: April 02, 2009, 11:36:34 AM »
Are you Herman?.... from the old happy days at the autolisp customization ng from adesk?
My guess is ... Herman Mayfarth. :)
