Author Topic: Changing Multiple single line txt to mtxt in one command sellection  (Read 2145 times)
SEGUL
Would anyone know or have a Autolisp command (AutoCAD 2009) that can change multiple single line text to mtxt without having all the single line txt combined into one mtxt.....iam working on a large drawing which has lots of individual single line text and i need to convert them to mtxt...simple as possible, like changing the txt style of individual txt.
Having to change each txt individually would take me hours or even a day.
Any suggestions or solutions to this issue would be most welcomed and acknowledged.....
kpblc
Sorry for my English.
Spike Wilbury
Re: Changing Multiple single line txt to mtxt in one command sellection
« Reply #2 on: March 29, 2009, 05:32:20 PM »
Try to load and use archieve at http://forum.dwg.ru/showpost.php?p=162618&postcount=21
<out of scope question, if I may>
Hi Alexey,
Is that forum, the same as in this one:
www.caduser.ru
That appears is kind of a new service or web design BTW
Regards,
Luis.
« Reply #3 on: March 29, 2009, 07:11:57 PM »
Welcome to The Swamp Segul.
Does this do what you want?
http://www.theswamp.org/index.php?topic=8903.msg119839#msg119839
