This would be good for everyone I think....
The Coordinates would be Attributes of the Title block, with a field expression giving output on the Zoomed View in the Viewport which the title block would be framing.
The Fields would return the correct modelspace Viewport view coordinates within a sheet set of more than 1 sheet.
%<\AcObjProp Object(%<\_ObjId 1974392920>%).Center \f "%lu2%pt2%pr0">% is a field expression to get the Y coordinate of the Centerpt of a View in a Viewport. I'm using MAP 3d 2007, and want my MAP Book generated Layouts ( > 1 Nr.) to have TitleBlocks with coordinates autofilled.
That means there has to be a link between the Layout and its title block attrs. The "...ObjID .." in the expression above is a little worrying as this needs to be created on the fly and then 1/2 the width and/or 1/2 Height Properties added to it to give the corner coordinates (Rectangular Viewport). That probly means I need to use Fieldexpression category "Sheet sets", but I'm not getting anywhere with that!
Anyone any ideas???
