Author Topic: rotate a list  (Read 2906 times)
curmudgeon
rotate a list
« on: March 19, 2009, 09:23:10 PM »
I am confused. I have a list of points to process, rotate like a stack in RP. I can
(setq foo (append (cdr foo) (list (car foo))) )
but when I try to make a subroutine of it
(defun rot_lst ( / )
old foo is new foo, or setq is not setting q.
the list does not rotate.
Never express yourself more clearly than you are able to think.
Re: rotate a list
« Reply #1 on: March 19, 2009, 09:43:04 PM »
Ha ha, foo you. Sorry, couldn't resist. :D
(defun rotate ( lst )
    (append
        (cdr lst)
        (list (car lst))
(setq lst '(1 2 3))
(rotate lst) => (2 3 1)
(rotate (rotate lst)) => (3 1 2)
(rotate (rotate (rotate lst))) = > (1 2 3)
/shrug
PS: What's RP?
curmudgeon
Re: rotate a list
« Reply #2 on: March 19, 2009, 09:50:37 PM »
thanks
RP - reverse polish notation like the old HP calculators use.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: rotate a list
« Reply #3 on: March 19, 2009, 10:17:12 PM »
thanks
:)   and like the new ones too :)
1 ENTER 1 +
30 ENTER 15 TAN *
Called Kerry in my other life
I live at UTC + 13.00
Re: rotate a list
« Reply #4 on: March 19, 2009, 10:26:43 PM »
Well if ya had said RPN stack I wouldn't have asked. I've owned a 10c, 11c, 42cx, 28s and and a 35s. Weirder yet, earlier today I had suggested to a colleague he code up a RPN calculator in Python. :D
Re: rotate a list
« Reply #5 on: March 20, 2009, 12:22:03 AM »
thanks
What do you mean OLD. :-o
I use my HP12C every day. 8-)
PS I know it as RPN
curmudgeon
Re: rotate a list
« Reply #6 on: March 20, 2009, 03:50:57 AM »
"Well, I'm back." he said.
I am running Autocad 2000, and vlisp, and it seems that I have no definition for ROTATE.
But I do have a deadline of about 10:30 Central Standard ( daylight savings ) Time.
I have 8 hours. But this is still a fun room.
I can (setq points (append (cdr points) (list (car points)))). It works to do this thing.
My original curiosity was, and is, why when I put that in a (defun ) it doesn't change points permanently when I (setq).
 ((5101.57 2550.21) (5080.36 2571.42) (5046.57 2571.42) (5011.65 2571.42) (4990.44 2550.21) (5037.45 2503.2) (5054.56 2503.2))
would be an example of my points.
When I (append (cdr points) (list (car points))) I get
 ((5080.36 2571.42) (5046.57 2571.42) (5011.65 2571.42) (4990.44 2550.21) (5037.45 2503.2) (5054.56 2503.2) (5101.57 2550.21))
which is nifty - especially sans a ROTATE.
WOW! It is so much nicer to type with colour.
Anyway, I love deadlines. I love the whooshing noise they make as they pass. But I think that as long as I am breathing I will want to know the stuff I don't know, and this nugget is on the list of stuff to comprehend.
thanks,
roy
curmudgeon
Re: rotate a list
« Reply #7 on: March 20, 2009, 03:59:08 AM »
Oh, yeah. RPN. Maybe dropping the "N" was a local thing, I seem to remember saying it both ways in school. And maybe my memory is no better than that.
 :ugly:
(AND (= local_thing explanation) (< memory was_memory))
T
Re: rotate a list
« Reply #8 on: March 20, 2009, 10:03:20 AM »
"Well, I'm back." he said ...
Well the only thing I can surmise is that the function you posted in your initial thread didn't represent what you were actually using off line.
To be more direct, you posted this:
    (setq foo (append (cdr foo) (list (car foo))))
Whereas I'm guessing you were actually using this:
(defun rot_lst ( [color=red]foo[/color] )
Using the second definition thusly:
(setq lst '(A B C))
(rot_lst lst) => (B C A)
While (rot_lst lst) returns (B C A) the variable lst will still be bound to (A B C). Why? Because the argument foo hosts a copy of the data, not the original -- any changes made to foo are local to the rot_lst function and independent of the external variable lst. So while (rot_lst lst) returns the result you want, said results are not permanent -- unless you capture them:
(setq lst (rot_lst lst))
Then again I've quite likely missed your point, but unfortunately I cannot help myself; sorry + shrug.
curmudgeon
Re: rotate a list
« Reply #9 on: March 22, 2009, 07:34:04 AM »
thank you very much. I did not really understand my own question, but your answer is the best explanation of what I was misunderstanding I have yet seen.
I was mistaken about this very basic concept from the (my) beginning(s).
by way of explanation, I had been working at a different computer, and did not have the url for the swamp there. it took me time to get back here. I had gone to afralisp.net, and reviewed the difference between set and setq, and I almost had it.
I may take your words and put them on my refrigerator for a while - till it really sinks in.
again, thanks.  :-)
PS
I would like to say that I only know what I have picked up along the way. I have no teaching other than the help files and groups like this one - my own files and my own time. in this "project" I have also learned how I can use (princ) to do more than just close quietly.
I am learning quite a lot on this one. all my code is about to get a lot better.
« Last Edit: March 22, 2009, 08:03:57 AM by curmudgeon »
Re: rotate a list
« Reply #10 on: March 22, 2009, 09:30:44 AM »
In other words, you're just like us.
Glad you got the help you wanted and are enjoying your programming, happy ones and zeros ...
Re: rotate a list
« Reply #11 on: March 22, 2009, 01:04:44 PM »
Yep, welcome to the club, Roy!
