Author Topic: Problem Block and Layer Merge  (Read 6103 times)
craigr
« on: March 19, 2009, 11:54:08 AM »
I have a problem block that I can't figure out - See attached.
It is a 'copyright' stamp we have on our Title Block. For some reason, with this block in our dwg, the layer merge command won't merge ANY layers. If I delete the block and purge, then re-run the Layer Merge command, it works fine.
I can't figure why it would make a difference but it does every time on all dwgs that have this block.
So when we want to run the layer merge, we have to go thru the process of deleting this block then adding it back in when we are finished.
Do any of you have an idea of what is causing this?
craigr
M-dub
Re: Problem Block and Layer Merge
« Reply #1 on: March 19, 2009, 12:01:19 PM »
You must be trying to get rid of the TITLE_BLOCK layer.
Everything in that block is on that layer.  Go in and change everything to layer 0 and purge TITLE_BLOCK layer out of that file and save it.  Then go and redefine the block in your drawing and it should work.
M-dub
« Reply #2 on: March 19, 2009, 12:04:09 PM »
Oh, actually, that's a block OF a block called Copyright.
Still, once its exploded, everything is on the TITLE_BLOCK layer.
craigr
« Reply #3 on: March 19, 2009, 12:04:25 PM »
No, 'Title_Block' is our 'standard' layer and has everything that doesn't get changed on it. It is in EVERY dwg we do.
For some reason, if I want to merge layer '2' into layer '3' it won't work unless I erase the 'copyright' block first.
craigr
M-dub
« Reply #4 on: March 19, 2009, 12:07:47 PM »
Oops... sorry.
have you tried changing the current layer before LAYMRG instead of deleting this block?
craigr
« Reply #5 on: March 19, 2009, 12:10:42 PM »
Oops... sorry.
I am typically on layer '0' when I am merging layers. I NEVER use the Title block for anything but our 'standards' that are on that layer. Nothing is every added or deleted from that layer, so I am never on that layer. Basically, it is just ignored, because it is just the 'Title Block'. I keep it locked so when eraseing & moving things, I don't have to worry about grabbing it by mistake.
craigr
craigr
« Reply #6 on: March 19, 2009, 12:28:31 PM »
I have created a 'typical' dwg that has the block in it and reproduces the problem.
If you think you can figure it out, give it a try. - See attached.
craig
M-dub
« Reply #7 on: March 19, 2009, 12:31:40 PM »
All I can see is that by unlocking TITLE_BLOCK, LAYMRG works... it's the WHY that I can't figure out, unless that command is just one of the few commands that locking layers affects.
CottageCGirl
« Reply #8 on: March 19, 2009, 12:33:59 PM »
why can't I explode the copywright block..is it a block?
craigr
« Reply #9 on: March 19, 2009, 12:37:39 PM »
The copyright is in PSpace.
If you unlock the layer, you CAN explode it.
M-dub
« Reply #10 on: March 19, 2009, 12:48:56 PM »
and the copyright symbol ( © ) is text
craigr
« Reply #11 on: March 26, 2009, 08:31:39 AM »
Well I decided to try something else.
I made a new block to replace the old. I then erased the old block from the dwg, purged a couple of times, then inserted the new block. I then tried the Layer Merge and STILL have the problem.
This tells me that it shouldn't have anything to do with the block, but it does. If I remove the block from the dwg, The layer merge works fine.
Any other ideas would be welcomed.
craigr
M-dub
« Reply #12 on: March 26, 2009, 08:43:28 AM »
I don't know... that is strange, and I've had a few drawings that have caused me problems with that command too.  I just didn't have time to screw around with it and just did it manually.
Gotta think on it a bit
craigr
« Reply #13 on: March 26, 2009, 08:47:13 AM »
Sadly, that is one of my flaws. - I have a very tough time with 'that's just the way it is. Let it go'.
I REALLY want things to work right, and always spend too much time on trying to figure out why they don't.
I will just keep pecking away at it and one of these days / years, I will figure it out.
craigr
Matt__W
  • I like my water diluted.
« Reply #14 on: March 26, 2009, 10:03:04 AM »
It works fine for me.   :|
AutoCAD MEP 2008
Have you tried auditing your drawing(s)?
Autodesk Expert Elite
