Author Topic: Copy Rotate Lisp help.  (Read 8064 times)
Artisan
« on: October 15, 2004, 01:44:16 PM »
I am having trouble with my lisp routine for a copy then rotate command I use. When I select the object to copy, it copies the object, allows me to place the copy where I need it and then when it rotates, it will rotate the original object instead of the copy. Here's the routine:
(DEFUN C:cR (/ SS P1 P2)
(PRINC "\nSelect objects Rob :")
(setq ss (ssget))
(if ss (progn
(setq P1 (getpoint "Basepoint :"))
(setq P2 (getpoint "Destination :"))
(command "COPY" ss "" P1 P2 "")
(command "rotate" ss "" P2)
M-dub
« Reply #1 on: October 15, 2004, 01:50:27 PM »
Here's the one I use...
;;COPYROT.LSP Copyright 1998 HyperPics all rights reserved
;;  Author:  Lee Ambrosius,
;;                HyperPics
;;              http://members.aol.com/HyperPics/Home.html
;;COPYROT is a command to allow you to copy an object and then do
;;a rotate right after it. Once loaded just type in COPYROT to activate
;;the command.
;;This is a great file to place inside of your ACAD.lsp file or use
;;it by itself.
;;  All documentation must stay with this Lips routine though.
;; Find and give me the Group nams in a lists
;; First string in list will be the last group created
(defun newgroups (/ GRPS OD GRP1 CHCKR GRPS GNAME)
  (setq OD (namedobjdict))
  (setq GRPS (dictnext OD "acad_group"))
  (while (/= CHCKR 3)
    (setq GRP1 (car GRPS))
    (setq GRPS (cdr GRPS))
    (setq chckr (car GRP1))
    (if (= chckr 3)
        (setq NGROUPS (list (cdr GRP1)))
  (while (/= GRPS nil)
    (if (= chckr 3)
        (setq GNAME (cdr GRP1))
        (setq NGROUPS (cons GNAME NGROUPS))
  (setq EXGNAME (car NGROUPS))
;;Error Tile
(defun MYERROR (S)
  (if (/= S "\nFunction cancelled" )
  (princ "\nEnding Copy Rotate..." ))
  (command "-group" "e" "copier")
  (command "undo" "end")
  (command "u" "u")
  (setvar "CMDECHO" CMD)
  (setq *ERROR* OLDERR )
;; Main section of Copy Rotate
(defun c:COPYROT (/ SS1 PT1 PT2)
  (setq SS1 nil)
  (setq CMD (getvar "CMDECHO"))
  (setq OLDERR *ERROR*)
  (setq *ERROR* MYERROR)
  (command "undo" "begin")
  (setvar "CMDECHO" 0)
  (prompt "\nSelect Objects to Copy-Rotate: ")
  (setq SS1 (ssget))
  (command "-group" "" "copier" "" SS1 "")
  (setq PT1 (getpoint "\nFirst Point of displacement: "))
  (prompt "\Second Point of Displacment: ")
  (command "._copy" "g" "copier" "" PT1 pause)
  (setq PT2 (getvar "LASTPOINT"))
  (prompt "\nSelect Angle of Rotation: ")
  (command "._rotate" "last" "" PT2 pause)
  (newgroups)
  (command "-group" "e" EXGNAME)
  (redraw)
  (prompt "\nCopy Rotate complete....")
) ;; End of Copy Rotate
(c:COPYROT)
ELOQUINTET
« Reply #2 on: October 15, 2004, 01:57:59 PM »
i got this one from someone here i think which contains both move and copy rotate
(defun c:mr  () (b-cmr "M")(princ))
(defun c:cr  () (b-cmr "C")(princ))
; File         : mcr.lsp
; Date         : 20-9-03
; Function     : (B-CMR <MODE>)
; Purpose      : Copy+Rotate or Move+Rotate
; Arguments    : <MODE> = "C" -> Copy-rotate
;                       = "M" -> Move-rotate
; Written by   : J.J.Damstra
(defun b-cmr (typ / ss1 temp p0 p1)
   (setq ss1 (ssget "I"))
   (command ".undo" "begin")
   (setq temp (getvar "CMDECHO"))(setvar "CMDECHO" 0)
   (if (not ss1)(setq ss1 (ssget)))
   (if ss1
         (initget 1)
         (setq p0 (getpoint "\nBasepoint : "))
         (if (= typ "C")
               (setq p1 (getpoint "\nTranslation or <ENTER>: " p0))
               (if (not p1)(setq p1 p0))
               (command ".copy" ss1 "" "0,0" "0,0")
            (while (not p1)(setq p1 (getpoint "\nTranslation : " p0)))
         (command ".move" ss1 "" p0 p1)
         (command ".rotate" ss1 "" p1 pause)
      (princ "\nMsg> Nothing selected! ")
   (command ".undo" "end")
   (setvar "CMDECHO" temp)
Artisan
« Reply #3 on: October 18, 2004, 08:16:44 AM »
Ok fellows, I have used the the following routine and I have one problem with it. Now when I open a drawing, the Copy-Rotate command starts as soon as the drawing opens.
(defun c:CR (/ SS1 PT1 PT2)
  (setq SS1 nil)
  (setq SS1 (ssget))
  (newgroups)
  (redraw)
(c:Cr)
daron
« Reply #4 on: October 18, 2004, 08:18:46 AM »
I believe it's because of (c:Cr) at the end of your code. Remove it or comment it out. ;;;
SMadsen
« Reply #5 on: October 18, 2004, 08:20:07 AM »
If the problem is that it runs upon loading then remove the line that invokes the command; the last line (c:CR)
SMadsen
« Reply #6 on: October 18, 2004, 08:20:46 AM »
Oh, hi Daron :)
daron
« Reply #7 on: October 18, 2004, 08:21:47 AM »
Hey, Stig.
Artisan
« Reply #8 on: October 18, 2004, 11:01:08 AM »
Good Deal, that worked. Thanks
Artisan
« Reply #9 on: October 19, 2004, 02:21:10 PM »
Ok, new problem now. I am using the lisp routine and all of a sudden I am getting this error:
Command: CR
Select objects: 1 found
Select objects:
<Selection set: 6>
; error: Function cancelled
Anyone seen this?
« Reply #10 on: October 19, 2004, 03:01:16 PM »
How about this?
;;  Copy Rotate a selection set
(defun c:cr (/ usercmd ss1 pt1)
  (setq usercmd (getvar "CMDECHO"))
  (if (and (setq ss1 (ssget))
           (> (sslength ss1) 0)
           (setq pt1 (getpoint "\nFirst Point of displacement: "))
      (command "._copybase" pt1 ss1 "")
      (command "._pasteclip" pt1); replace originals
      (command "._move" ss1 "" pt1 pause)
      (command "._rotate" ss1 "" (getvar "LASTPOINT") pause)
    (prompt "\nUser Quit....")
  (setvar "CMDECHO" usercmd)
Artisan
« Reply #11 on: October 19, 2004, 03:26:31 PM »
Good deal, it works for the time being. Thanks
