Author Topic: Remove-if ... etal  (Read 3772 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Remove-if ... etal
« Reply #15 on: March 12, 2009, 06:54:11 PM »
Oooops  :oops:
Thanks VovKA .. missed that
tried 3 run-throughs ..
Benchmarking [M.P. 2005] ............Elapsed milliseconds for 512 iteration(s)/ relative Timing :
    (_TEST01).....610 / 1.1152 <slowest>
    (_TEST04).....594 / 1.0859
    (_TEST02).....578 / 1.0567
    (_TEST05).....563 / 1.0293
    (_TEST03).....547 / 1
    (_TEST06).....547 / 1
    (_TEST07).....547 / 1 <fastest>
    (_TEST01).....625 / 1.1447 <slowest>
    (_TEST04).....625 / 1.1447
    (_TEST02).....578 / 1.0586
    (_TEST03).....578 / 1.0586
    (_TEST05).....563 / 1.0311
    (_TEST07).....563 / 1.0311
    (_TEST06).....546 / 1 <fastest>
    (_TEST01).....594 / 1.0859 <slowest>
    (_TEST04).....578 / 1.0567
    (_TEST06).....563 / 1.0293
    (_TEST03).....562 / 1.0274
    (_TEST07).....562 / 1.0274
    (_TEST05).....547 / 1 <fastest>
Copy of Michaels Benchmark routine with my mods ..
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
« Reply #16 on: March 12, 2009, 07:14:06 PM »
These are the reworked functions, revised to RETURN the Folder List for ALL functions.
The Benchmark Test can't make up it's mind ( consistently ) which function is faster
(defun _test01 ( / Folders)
  (setq Folders (vl-remove-if (function (lambda (g) (or (= g ".") (= g ".."))))
                              (vl-directory-files bom:ParentFolder NIL -1)
(defun _test02 ( / Folders)
  (setq Folders
         (vl-remove ".." (vl-remove "." (vl-directory-files bom:ParentFolder NIL -1)))
(defun _test03 ( / Folders)
  (if (= "." (car (setq Folders (vl-directory-files bom:ParentFolder NIL -1))))
    (if (= ".." (car (setq Folders (cdr Folders))))
  Folders
(defun _test04 ( / Folders)
  (setq Folders (vl-remove-if (function (lambda (g) (member g '("." ".."))))
(defun _test05 ( / Folders)
  (setq Folders
         (if (member ".." (setq Folders (vl-directory-files bom:ParentFolder NIL -1)))
           (cddr Folders)
           Folders
(defun _test06 ( / Folders)
  (if (= ".." (cadr (setq Folders (vl-directory-files bom:ParentFolder NIL -1))))
    (setq Folders (cddr Folders))
  Folders
(defun _test07 ( / Folders)
  (if (> (strlen bom:ParentFolder) 3)
    (cddr (vl-directory-files bom:ParentFolder NIL -1))
;; (setq bom:ParentFolder "C:\\Program Files")
(setq bom:ParentFolder "C:\\")
(benchMark '((_test01) (_test02) (_test03) (_test04) (_test05) (_test06) (_test07) ))
« Reply #17 on: March 12, 2009, 07:41:44 PM »
I believe the variability of the results has more to do with the unpredictability of what the system greater is doing when you're performing I/O via the vl-directory-files in each test invocation rather than stability of the benchmark function, tho I'm not inferring it is perfect. Anyway, since that portion of the code (vl-directory-files bom:ParentFolder NIL -1) is common to all functions it would be better to store the result of such to a global variable and then use said variable in each of the functions to be tested. After all, what you're wishing to bench is the performance of the code that deals with the "." .".." entries, not the I/O that retrieves them. To wit:
                                  _folders
      (setq Folders
             (vl-remove ".." (vl-remove "." _folders))
      (if (= "." (car (setq Folders _folders)))
      Folders
                                  _folders
      (setq Folders
             (if (member ".." (setq Folders _folders))
               (cddr Folders)
               Folders
      (if (= ".." (cadr (setq Folders _folders)))
      Folders
        (cddr _folders)
        _folders
    (setq _folders (vl-directory-files bom:ParentFolder NIL -1))
    (repeat 5
        (benchMark
           '(   (_test01)
                (_test02)
                (_test03)
                (_test04)
                (_test05)
                (_test06)
                (_test07)
Result (very consistant):
Elapsed milliseconds / relative speed for 65536 iteration(s):
    (_TEST03).....1641 / 1.91 <fastest>
    (_TEST06).....1672 / 1.88
    (_TEST07).....1719 / 1.83
    (_TEST02).....1797 / 1.75
    (_TEST05).....1906 / 1.65
    (_TEST01).....2844 / 1.10
    (_TEST04).....3141 / 1.00 <slowest>
    (_TEST03).....1672 / 1.88 <fastest>
    (_TEST07).....1703 / 1.84
    (_TEST05).....1891 / 1.66
    (_TEST01).....2875 / 1.09
    (_TEST07).....1718 / 1.83
    (_TEST02).....1781 / 1.76
    (_TEST05).....1921 / 1.64
    (_TEST01).....2859 / 1.10
    (_TEST03).....1656 / 1.89 <fastest>
    (_TEST06).....1656 / 1.89
    (_TEST07).....1687 / 1.85
    (_TEST02).....1781 / 1.75
    (_TEST05).....1921 / 1.63
    (_TEST01).....2829 / 1.10
    (_TEST04).....3125 / 1.00 <slowest>
    (_TEST06).....1656 / 1.90
    (_TEST07).....1688 / 1.86
    (_TEST01).....2813 / 1.12
Cheers. :)
kdub_nz
  • SuperMod
« Reply #18 on: March 12, 2009, 07:51:41 PM »
Yes Michael, I came to the same conclusion, and reworked my test code in a similar manner.
.. the discrepancy is further exacerbated by accessing a network folder, albeit on a GB system :)
« Reply #19 on: March 12, 2009, 07:55:01 PM »
cool :) well I'm out-a-here, been a long day :doa:
