As does parametric drawing...but we'll have to see how well it all actually works before deciding.
Let's see if that parametric drawing feature functions as well as associative dimensioning does. The emphasis added is mine. Notice they write the article as if it is YOUR fault that the feature does NOT function. :ugly:
Also notice how long the DEFECT has been around at least 8 years, and then thank a subscription customer.
My money says it is most likely STILL broken in the Theyv'e Done it to us again in 2010 version.
Applies to:
AutoCADŽ 2009
AutoCADŽ 2008
AutoCADŽ 2007
AutoCADŽ 2006
AutoCADŽ 2005
AutoCADŽ 2004
AutoCADŽ 2002
Issue
When doing associative dimensioning (DIMASSOC variable set to 2), the following message is displayed on the command line:
Specify second extension line origin: end of Non-associative dimension created.
Solution
This message indicates that
you are trying to dimension an unsupported object in model space. The dimension created by this process will be non-associative.
Following is a list of objects that are unsupported for associative dimensions:
All dimensions
Leaders
Tolerances
Multi-lines
Any block inserted using MINSERT command
Solids
Traces
3D Faces
Polygon mesh vertices
Polyline mesh vertices
Polyline meshes
Polygon meshes
3D Face records
Viewports
Hatches
Mirrored or non-uniformly scaled block references
Images
Custom objects that do not implement the AcDbDimProtocol for supporting associativity
