Author Topic: how to make Zoom Window in viewport of paperspace ??  (Read 2400 times)
bikelink
« on: February 04, 2009, 11:08:01 AM »
I'm looking without found it, something to perform a good zoom in a viewport in paperspace.
I'm not able to center my objects in my viewport.
If i run ZoomWin in viewport it works always in 3d ucs.
Have You got an Idea ?  I have the rights points in 3d but when i run the zoom Autocad return in plan view.
Resume:
Creation Layout
Creation some viewport
SettingViewpoint in viewport
_____________________________
Now here I need to center my objects in a particular viewport.
Any suggestion is appreciated!!!
thanks in advance for your attention.
Re: how to make Zoom Window in viewport of paperspace ??
« Reply #1 on: February 04, 2009, 12:22:58 PM »
To make a point ( a model space point ) the center of the viewport, change the property ' ViewCenter '.  You can use any of three properties to change the zoom of the viewport; ' ViewHeight ' ' StandardScale ' ' CustomScale '.  If you need more help on these, maybe someone here can help more, as I have not done anything with viewports and .Net, or you can look in the ObjectARX help docs.
bikelink
« Reply #2 on: February 04, 2009, 01:54:14 PM »
Thank You very much.
this night i'll try yout suggest ;)
