Author Topic: (AutoCAD LT) Is there a limit to How many paths you can set?  (Read 1963 times)
craigr
« on: February 03, 2009, 03:55:06 PM »
In CAD / Tools / Options / File Paths - Is there a limit to how many paths you can have set to search for blocks?
I currently have 335 blocks all dumped into one directory and would like to split them into various directories.
I figured before I do this I had better ask how many directories I can have.
craigr
Matt__W
  • I like my water diluted.
Re: Is there a limit to How many paths you can set?
« Reply #1 on: February 03, 2009, 04:13:45 PM »
I'm sure you'd suffer some sort of performance hit if you added 335 support paths.  How many are you talking about?  I've got 18 support paths mapped.
Autodesk Expert Elite
craigr
« Reply #2 on: February 03, 2009, 04:14:38 PM »
Probably no more than 18, so I guess I will be okay.
Thanks.
