Author Topic: Painfully Slow Regens C3D2009  (Read 5593 times)
CHulse
« on: January 27, 2009, 06:10:59 AM »
Am I just expecting too much? Even relatively simple drawings are taking forever to regen.  :x
Does anyone have any suggestions to improve this?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
doggarncity
Re: Painfully Slow Regens C3D2009
« Reply #1 on: January 27, 2009, 07:45:37 AM »
First offering would to set your pagefile size to be a min. of 3 gig or more. The other pain is your anti-virus software. I could use microsoft one care because it uses the least resources of any. Symantec/McAfee can rob 30% plus of your computing power. Of course, make sure you have enough memory that has a speed, I would recommend of 1066 hz plus and a quad core processor. Also would get a Quadro Fx card at least starting at FX 1500 level or above. These are the simple ones. Check your task manager and test to see if you have other things running at the same time that hog resources. The other experts here will be adding there recommendations that should provide you with any other remedies.
Mike P
sinc
« Reply #2 on: January 27, 2009, 08:13:23 AM »
A couple of things:
Most people should not need to mess with the pagefile settings.  The defaults should work fine.  And these days, I have not been able to find any reason to get something like a Quadro.  The GeForce 9600GTS outperforms the Quadro FX1500 by quite a bit, and it only costs about $150.
But neither should have a big impact on regens for a nearly-empty drawing.  Virus software should not impact regens, either.  There really was not enough info given to help diagnose this problem.  Computer specs?  Version of C3D? (Oh, I see in the sig it's C3D 2009.)  In any case, it sounds like there is something strange happening.
CHulse
« Reply #3 on: January 27, 2009, 08:32:27 AM »
Ok, sorry for the short question - I'm just getting really frustrated with this. :ugly:
A bit more:
I recently decided that C3D (2009 w/SP1) was working well enough for me to uninstall my LDD 2008. I noticed the slow regens around the same time (I don't remember exactly when I first noticed it). C3D had been working quite well before. I have an HP Mobile Workstation 8710w with a Quadro FX 1500M, 4gb ram, and the page file is set way high (around 6gb) - good machine.
I also had installed SP2 for C3D around that time. Again, I don't remember exactly.
I have tried uninstalling SP2 and a repair with no real change. I'm thinking I may need to do a complete wipe and reinstall. :(
Thanks for your help
Cary Hulse
« Reply #4 on: January 27, 2009, 08:39:23 AM »
Everything in C3D '09 is painfully slow for me, well in a file that has many points.
CHulse
« Reply #5 on: January 27, 2009, 08:44:09 AM »
That's the thing - this is happening in empty files too. You might expect it in a big project, but in a new file with nothing??
Cary Hulse
doggarncity
« Reply #6 on: January 27, 2009, 09:16:49 AM »
A couple of things:
I mentioned Quadro only because it has speicific performance drivers for 2009 autocad that when I tested it for regens were near equal to a GTX 280 without those performance drivers and you can get a 1500 for about $150 on ebay now. That was tested on large files. I got to test 2 different Quadro's 1500 and the fx 4600, both made my C3D start 2nd time load in about 5 sec. First time load about 40 sec. You are right about config on machines, to many variables. Yes, on the something wrong with the dwg. Maybe use a different template dwg and redo.
Mike P
CHulse
« Reply #7 on: January 27, 2009, 09:30:14 AM »
A couple of things:
Mike P
It is not a problem with any specific dwg - it happens with all drawings (mine or those I get from outside)
Cary Hulse
sinc
« Reply #8 on: January 27, 2009, 09:52:18 AM »
Yes, sounds like you need to do a complete repair.  Uninstalling old versions of Autodesk stuff sometimes causes issues with the products that remain, and you may need to repair the remaining products.
However, more likely it has something to do with whatever you did when you "tried uninstalling SP2".  You can't uninstall a service pack - the only thing you can do is completely uninstall C3D, and reinstall it without the SP.
CHulse
« Reply #9 on: January 27, 2009, 10:02:34 AM »
Well that's probably it then. I used the windows "Add/Remove Programs" and the SP was listed. It said it removed it. BUT- I see it's still there in the list. I guess a clean install is in order...
...although I only tried to uninstall the SP after I started having problems...?
...sets off to get a hammer and a cup of coffee...
Cary Hulse
sinc
« Reply #10 on: January 27, 2009, 10:04:10 AM »
Something's wrong in that picture.  Your graphics card should have no significant effect on load time.
In any case, the GeForce 9600 GTS outperforms the Quadro FX1500 by quite a bit, so if the price is the same, I'd go with a brand-new 9600 GTS over a used (and possibly abused) Quadro FX1500.
It's a moot point for this thread, anyway, because the OP does have extensive hardware.  But like I said, even with poor hardware, the OP should not have been seeing the problem he was describing.
sinc
« Reply #11 on: January 27, 2009, 10:08:33 AM »
Oh wait, I suppose that won't necessarily work...  The GeForce 9600 GTS is PCIe 2.0, while the Quadro FX1500 is PCIe 1.0.  So you can use the Quadro on older machines that won't take the newer GeForce.  In that case, the Quadro looks better.
CHulse
« Reply #12 on: January 27, 2009, 10:13:26 AM »
I thought the Quadro cards were better suited to CAD then the GeForce? Or has that changed recently?
Cary Hulse
« Reply #13 on: January 27, 2009, 10:23:10 AM »
CHulse,
How is the uninstall - install going?
I think the GeForce vs Quadro argument is that one can get more ram and faster clock speed per dollar on those cards at the same or lower price point than a Quadro chipped card.  These better specifications do a fine job of compensating for not having the audocad specific drivers.
Alan Cullen
« Reply #14 on: January 27, 2009, 10:36:33 AM »
Well...I've had a gut full of my motherboard...keeps freezing, ram doesn't show that it's actually there.
A P5B Asus (?)..anyone ever heard of it? I've had it back in for 2 weeks of testing.....and I got zip response. 2 gig ram.....I am not happy. I have $3000 left over from my mexican trip, so should I just get a new computer or upgrade the motherboard on this one?
