Author Topic: Filter by Z-Value  (Read 6850 times)
Rooster
Filter by Z-Value
« on: January 14, 2009, 09:38:32 AM »
I'm trying to use a LISP that I've edited to select all objects with a z-value of -999, but when I run it AutoCAD doesn't pick anything up. Can anyone see where I'm going wrong?
(defun c:fz999(/ cSet)
  (setq cSet(ssget
      '((10 . *, *, -999))
      ); end ssget
  ); end setq
(if cSet
     (princ(strcat "\n" (itoa(sslength cSet)) " found."))
     (sssetfirst nil cSet)
  ); end progn
  (princ "\nNothing found. ")
); end if
); end of c:fz999
Re: Filter by Z-Value
« Reply #1 on: January 14, 2009, 10:09:42 AM »
Rooster
« Reply #2 on: January 14, 2009, 10:14:36 AM »
Ah - thankyou. That looks promising......
« Reply #3 on: January 14, 2009, 10:16:17 AM »
« Reply #4 on: January 14, 2009, 10:18:07 AM »
Let us know if you still have trouble with it.
Rooster
« Reply #5 on: January 14, 2009, 10:32:14 AM »
Thanks - I used your first example to get this....
;FILTERS ALL OBJECTS WITH Z-VALUE OF -999
(defun c:fz9(/ cSet)
  (setq cSet(ssget "X"
               '((-4 . "*,*,=") (10 . 0.0 0.0 -999.0))
             ); end ssget
   ); end setq
  (if cSet
      ); end progn
    ); end if
  ); end of c:fz9
....and that worked for me once, but now when I try to run my LISP again I get an 'Unknown Command' error upon entering fz9, which is really puzzling me. I've made sure of all the obvious things like no typos, LISP loaded into drawing, etc.
« Reply #6 on: January 14, 2009, 10:40:26 AM »
Try this one:
;;FILTERS ALL OBJECTS WITH Z-VALUE OF -999
(defun c:fz9 (/ cSet)
  (if (setq cSet (ssget "X"
'((-4 . "*,*,=") (10 0.0 0.0 -999.0))
      (princ (strcat "\n" (itoa (sslength cSet)) " found."))
    ;; end progn
  ;; end if
;; end of c:fz9
« Reply #7 on: January 14, 2009, 10:41:50 AM »
You had a dot that didn't belong.
Use this
(10 0.0 0.0 -999.0)
Urg, Ron's just too fast. :-)
dustinthiesse
« Reply #8 on: January 14, 2009, 10:44:36 AM »
Take a look here: 8-)
http://www.theswamp.org/index.php?topic=1333.msg16766#msg16766
Nice.  I had never seen that done before.  I was testing it out on some drawings that we received from some other company where they had things on all kinds of different Z levels.  I used
(setq sset(ssget "X" '((-4 . "*,*,/=")(10 0.0 0.0 0.0))))
to grab everything not on Z=0 and then set them all to zero.
It worked on most of the entities, but it doesn't seem to find the Mtext and Leaders.  None of those object types changed value, and the above statement returns nil even though there are objects set to other various Z values.
I even inspected a couple of the entities to make sure that the group 10 DXF code did have a value other than 0.0 for the Z position which turned out to be true.  Any ideas?
Rooster
« Reply #9 on: January 14, 2009, 10:46:49 AM »
Ah - so simple. Thanks :)
Rooster
« Reply #10 on: January 14, 2009, 10:53:19 AM »
Ok, now my problem is that on my function for filtering all objects with a z-value of 0 I'm getting 3D polylines selected, even though their z-values are not 0 - being polylines, they have multiple z-values. How do I get around this?
;FILTERS ALL OBJECTS WITH Z-VALUE OF 0
(defun c:fz0(/ cSet)
  (setq cSet(ssget
               '((-4 . "*,*,=") (10 0.0 0.0 0.0))
             ); end ssget
   ); end setq
  (if cSet
      ); end progn
    ); end if
  ); end of c:fz0
EDIT: looking at the DXF codes of the 3D polylines, their group 10 value is 0.0, so obviously it's another group code that I need to work with, but I can't work out which one.....
« Last Edit: January 14, 2009, 10:59:48 AM by Rooster »
« Reply #11 on: January 14, 2009, 11:06:59 AM »
You could mess around with this filter....not sure if it will work for you since it disregards 3dpoly's.
'((-4 . "<OR")
  (-4 . "*,*,=")
  (10 0.0 0.0 -999.000)
  (38 . -999.0);;polyline elevation
  (-4 . "<NOT")
  (100 . "AcDb3dPolyline");;not 3d poly's
  (-4 . "NOT>")
  (-4 . "OR>")
Rooster
« Reply #12 on: January 14, 2009, 11:12:39 AM »
Thanks ronjonp, but that's still picking up my 3D polylines that I want it to leave well alone.....
« Reply #13 on: January 14, 2009, 11:20:21 AM »
d-unit
could you post a sample DWG for testing?
dustinthiesse
« Reply #14 on: January 14, 2009, 11:30:12 AM »
d-unit
There are 4 Mtext and 3 leader objects that are at Z=2700 that will not go to Z=0 using the attached code.
Thanks in advance CAB.
(Also, it looks like there is a block that has an attribute on a different Z value as well.  I haven't looked into that one yet.)
