Author Topic: Linking attributes to parameters with calculations?  (Read 9120 times)
CHulse
« on: January 09, 2009, 02:59:31 PM »
Is it possible to pass numeric data from an attribute on to a parameter (linear) with a calculation (such as multiply it by 1.5)?
Is it possible to pass numeric data from an attribute on to another attribute with a calculation?
Is it possible to pass data from a parameter to an attribute?
and if any of this is possible, how please?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
jnieman
Re: Linking attributes to parameters with calculations?
« Reply #1 on: January 09, 2009, 03:00:23 PM »
Not
yet.
CHulse
« Reply #2 on: January 09, 2009, 03:01:14 PM »
well that was easy...
Cary Hulse
jnieman
« Reply #3 on: January 09, 2009, 03:02:55 PM »
depending on application, this may help.
http://www.dailyautocad.com/autocad/parametric-blocks/
CHulse
« Reply #4 on: January 09, 2009, 03:15:42 PM »
Well, what I'd like to ultimatly do is insert a block and enter a unique ID# (tree number) as a single attribute. Then I'd like it to link to a database, look up other data about the tree and adjust a set of linear parameters accordingly.
Short of that, I was hoping it could take an attribute with a tree diameter and calculate a couple of other parameters from it.
Currently, I just enter the various parameters as calculated in an excel sheet manually into a VBA form that passes them to the block before I place it.
Pipe dreams perhaps...
Cary Hulse
jnieman
« Reply #5 on: January 09, 2009, 03:37:40 PM »
There is ="currently"= in Autocad 2009, no way to make "Dimension A" equal to "Dimension B plus 8.44cm"
However, there is a "lookup" function to dynamic blocks that may get you by.
http://www.dailyautocad.com/autocad/dynamic-blocks-and-lookup-parameter/
« Reply #6 on: January 09, 2009, 03:49:22 PM »
This can be done to some extent with Description Keys in C3D.
You could also do this with a Range Table in MAP.
CHulse
« Reply #7 on: January 09, 2009, 03:52:00 PM »
Could you elaborate please?
Cary Hulse
jnieman
« Reply #8 on: January 09, 2009, 03:53:38 PM »
oops, didn't notice the C3D tag in his signature... *bows out*
CHulse
« Reply #9 on: January 09, 2009, 03:55:23 PM »
Cool, I wondered what those were. ...but I need to be able to enter any number from 1 to 100 or more including decimals.
Cary Hulse
CHulse
« Reply #10 on: January 09, 2009, 03:55:52 PM »
I appreciate the help!
Cary Hulse
« Reply #11 on: January 09, 2009, 03:58:16 PM »
With Description Keys one has use of up to 9 string characters to describe the point. Be default the first  is used to SCALE the point symbol (like a tree), the second to rotate the symbol.
The process with MAP and range tables is a little more complicated.  However one does this through a querry operation.
You can see the Description Keys set up on my site www.primeservicesgloabl.com on the free tutorials page found there.
CHulse
« Reply #12 on: January 09, 2009, 04:04:31 PM »
I'll check it out, thanks Michael
Cary Hulse
whdjr
« Reply #13 on: January 12, 2009, 08:51:03 AM »
How about creating your own xdata for your specific items?  That's essentially what the Description Keys are if I'm not mistaken.
