Author Topic: a "return" inside an "if" (C#)  (Read 3167 times)
A_LOTA_NOTA
« on: January 09, 2009, 10:44:31 AM »
Is it possible to have a “return” inside an “if”? I have pasted below what I’m trying to do. Maybe I’m going about it all wrong but I know someone here can set me strait.
   // Was something selected?
            if (ssResult.Status != PromptStatus.OK)
                ed.WriteMessage("\nNothing was selected");
            // Something was selected
            else
                ObjectId[] objIds = ssResult.Value.GetObjectIds();
                return objIds;
Re: a "return" inside an "if" (C#)
« Reply #1 on: January 09, 2009, 10:58:29 AM »
Yes, but you need to have a return if nothing was selected.  So either in the first portion of the if statement, or after the if statement is executed.
A_LOTA_NOTA
« Reply #2 on: January 09, 2009, 11:03:16 AM »
So somthing like this should work?
                return new ObjectId[] {};
            else
                return objIds;
« Reply #3 on: January 09, 2009, 11:05:27 AM »
Assuming that your function returns an ObjectId[], then yes.
A_LOTA_NOTA
« Reply #4 on: January 09, 2009, 11:08:56 AM »
Yes it does & yes it works!
Thanks for your help!
« Reply #5 on: January 09, 2009, 11:17:38 AM »
You're welcome.  With C#, you have to make sure that each path the code can take will return the type defined by the function.
A_LOTA_NOTA
« Reply #6 on: January 09, 2009, 01:05:36 PM »
Thanks for your help Tim. I knew someone would point me in the right direction. It is nothing spectacular just a place to start learning.
namespace My_AutoCAD_Managed_CS_Project_Application1
    public class GetEntity
        [CommandMethod("Test")]
        public static void Testing()
            Transaction tr = doc.TransactionManager.StartTransaction();
            ObjectId entity = GetSingleEntity();
            var ent = (Entity)tr.GetObject(entity, OpenMode.ForWrite);
            ent.ColorIndex = 1;
            tr.Commit();
        }// end Testing
        [CommandMethod("GetEntity")]
        public static ObjectId GetSingleEntity()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            //Create a new entity selection options object
            var entitySelectionOpts = new PromptEntityOptions("\nSelect Object: ");
            //Start the selection process
            PromptEntityResult entitySelectionResult = ed.GetEntity(entitySelectionOpts);
            // Was something selected?...
            if (entitySelectionResult.Status != PromptStatus.OK)
                return new ObjectId();
                // Something selected, so...
            else
                ObjectId objIds = entitySelectionResult.ObjectId;
                return objIds;
        }// end GetSingleEntity
    }// end class
}// end namespace
Glenn R
« Reply #7 on: January 12, 2009, 11:25:31 AM »
I would change your return statement from this:
to this:
return ObjectId.Null;
That is the way to signify a null or invalid ObjectId.
