Author Topic: Multithreading with VB.net  (Read 2454 times)
ChuckHardin
« on: January 08, 2009, 01:54:50 PM »
I am trying to understand multithreading with VB.net.
Here is what I am doing it all works for now but This is my first try at it.
Can anyone see any problems with this. the timer ticks every 10 seconds.
It will be updating the database next.
Form Main
Imports System.Data.OleDb
Imports System.Threading
Public Class frmMain
    Dim sTrucks() As String
    Dim lngCnt As Long
    Private Sub frmMain_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim strTrucks As String
        strTrucks = "59|1;41|2;42|3;45|4;47|5"
        sTrucks = Split(strTrucks, ";")
    End Sub
    Private Sub Timer1_Tick(ByVal sender As Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        Dim intcnt As Int32
        Dim t As Thread
        Dim ThisTruck() As String
        lngCnt += 1
        Label1.Text = lngCnt
        For intcnt = LBound(sTrucks) To UBound(sTrucks)
            Dim oUpdateTruck As New UpdateTruck
            'Set the Truck Number and ID
            ThisTruck = Split(sTrucks(intcnt), "|")
            Label2.Text = sTrucks(intcnt)
            Application.DoEvents()
            oUpdateTruck.strTruckNum = CStr(ThisTruck(0))
            oUpdateTruck.strTrkID = CStr(ThisTruck(1))
            'Set up a new Thread
            t = New Thread(AddressOf oUpdateTruck.UpdateTrucksPosition)
            'Start the Thread
            t.Start()
        Next 'Go to the next truck and start a new thread
    End Sub
End Class
Class UpdateTruck
Imports System.Net.Sockets
Public Class UpdateTruck
    Public strTruckNum As String
    Public strTrkID As String
    Public Sub UpdateTrucksPosition()
        Dim strTrucksConnectionString As String
        Dim dblGps_Return(0 To 3) As Double
        Dim UpdateSQL As String
        strTrucksConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=\\ceccfile\updates\Files\VehicleTracker\Data\VehLocation.mdb"
        Dim UpdateTruck As New OleDb.OleDbConnection(strTrucksConnectionString)
        dblGps_Return = GetTruckGPSInfoByTruckNumber(strTruckNum)
        If dblGps_Return(0) > -1 Then
            UpdateSQL = "Update VehLocation Set"
            UpdateSQL += " Latitude=" & CStr(dblGps_Return(0))
            UpdateSQL += ", Longitude=" & CStr(dblGps_Return(1))
            UpdateSQL += ", Speed=" & CStr(dblGps_Return(2))
            UpdateSQL += ", Direction=" & CStr(dblGps_Return(3))
            UpdateSQL += ", DTStamp=#" & CStr(Date.FromOADate(dblGps_Return(4))) & "#"
            UpdateSQL += " Where TrkID=" & strTrkID
            Debug.Print("Status" & Format(Now, "mm/dd/yy hh:mm:ss") & ": " & UpdateSQL)
            Dim UpdateTruckComm As New OleDb.OleDbCommand(UpdateSQL, UpdateTruck)
            UpdateTruckComm.Connection = UpdateTruck
            UpdateTruckComm.Connection.Open()
            UpdateTruckComm.ExecuteNonQuery()
            UpdateTruck.Close()
        End If
    End Sub
    Private Shared Function GetTruckGPSInfoByTruckNumber(ByVal sTruck As String)
        On Error GoTo Err_Control
        Dim dGPS_Info(0 To 4) As Double
        dGPS_Info(0) = -1
        dGPS_Info(1) = -1
        dGPS_Info(2) = -1
        dGPS_Info(3) = -1
        dGPS_Info(4) = -1
        Dim strResponse() As String
        Dim strParsedResponse() As String
        Dim intcnt As Integer
        Dim port As Int32 = 9494
        Dim client As New TcpClient("cecc-trk" & sTruck & ".eairlink.com", port) '"cecc-trk" & sTruck & ".eairlink.com"
        Dim dLat As Double
        Dim dLong As Double
        Dim dSpeed As Double
        Dim dDirection As Double
        Dim TruckDT As DateTime
        ' Get a client stream for reading and writing.
        '  Stream stream = client.GetStream();
        Dim stream As NetworkStream = client.GetStream()
        Dim MyData As [Byte]()
        ' Receive the TcpServer.response.
        ' Buffer to store the response bytes.
        MyData = New [Byte](256) {}
        ' String to store the response ASCII representation.
        Dim responseData As [String] = [String].Empty
        ' Read the first batch of the TcpServer response bytes.
        Dim bytes As Int32 = stream.Read(MyData, 0, MyData.Length)
        responseData = System.Text.Encoding.ASCII.GetString(MyData, 0, bytes)
        strResponse = Split(responseData, vbCrLf)
        For intcnt = LBound(strResponse) To UBound(strResponse)
            If InStr(strResponse(intcnt), "$GPRMC") > 0 Then
                '1   220516     Time Stamp
                '2   A(validity - A - ok, V - invalid)
                '3   5133.82    current Latitude
                '4   N(North / South)
                '5   00042.24   current Longitude
                '6   W(East / West)
                '7   173.8      Speed in knots
                '8   231.8      True course
                '9   130694     Date Stamp
                '10  004.2      Variation
                '11  W(East / West)
                '12  *70        checksum
                strParsedResponse = ParseGPSString(strResponse(intcnt))
                If strParsedResponse(2) = "A" Then
                    TruckDT = ParseDateTimeFromGPS(strParsedResponse(9), strParsedResponse(1))
                    dLat = CStr(CDbl(Strings.Left(strParsedResponse(3), 2)) + (CDbl(Strings.Right(strParsedResponse(3), Len(strParsedResponse(3)) - 2)) / 60))
                    If strParsedResponse(4) = "S" Then
                        dLat = -1 * dLat
                    End If
                    dLong = CDbl(Strings.Left(strParsedResponse(5), 3)) + (CDbl(Strings.Right(strParsedResponse(5), Len(strParsedResponse(5)) - 3)) / 60)
                    If strParsedResponse(6) = "W" Then
                        dLong = -1 * dLong
                    End If
                    If strParsedResponse(7) = "" Then strParsedResponse(7) = "0"
                    If strParsedResponse(8) = "" Then strParsedResponse(8) = "0"
                    dSpeed = CDbl(strParsedResponse(7)) * 1.150779
                    dDirection = strParsedResponse(8)
                    dLat = Math.Round(dLat, 6)
                    dLong = Math.Round(dLong, 6)
                    dSpeed = Math.Round(dSpeed, 1)
                    dDirection = Math.Round(dDirection, 1)
                    dGPS_Info(0) = dLat
                    dGPS_Info(1) = dLong
                    dGPS_Info(2) = dSpeed
                    dGPS_Info(3) = dDirection
                    dGPS_Info(4) = TruckDT.ToOADate()
                End If
                Exit For
            End If
        Next
        ' Close everything.
        stream.Close()
        client.Close()
Exit_Here:
        Return dGPS_Info
        Exit Function
Err_Control:
        Select Case Err.Number
            Case Else
                'Form1.Label1.Text = "Status" & Format(Now, "mm/dd/yy hh:mm:ss") & ": " & Err.Number & ": " & Err.Description
                Resume Exit_Here
        End Select
    End Function
    Private Shared Function ParseGPSString(ByVal sToParse As String)
        Dim strReturn() As String
        strReturn = Split(sToParse, ",")
        Return strReturn
    End Function
    Private Shared Function ParseDateTimeFromGPS(ByVal GPSDate As String, ByVal GPSTime As String) As DateTime
        Dim sTempDate As String
        Dim sTempTime As String
        Dim TimeOffset As Integer
        Dim iHours As Integer
        Dim dtReturn As DateTime
        TimeOffset = DateDiff(DateInterval.Hour, Now, Date.UtcNow)
        iHours = CInt(Strings.Left(GPSTime, 2))
        iHours = iHours - TimeOffset
        sTempDate = Strings.Mid(GPSDate, 3, 2) & "/" & Strings.Left(GPSDate, 2) & "/" & Strings.Right(GPSDate, 2)
        GPSTime = CStr(CLng(GPSTime))
        sTempTime = CStr(iHours) & ":" & Strings.Mid(GPSTime, 3, 2) & ":" & Strings.Right(GPSTime, 2)
        dtReturn = CDate(sTempDate & " " & sTempTime)
        Return dtReturn
    End Function
End Class
TonyT
Re: Multithreading with VB.net
« Reply #1 on: January 08, 2009, 04:09:03 PM »
You can use multiple threads for external processing, but what
you cannot do, is access any AutoCAD database objects from
those threads.
Form Main
    Dim lngCnt As Long
    End Sub
        Dim intcnt As Int32
        Dim t As Thread
        lngCnt += 1
            'Start the Thread
            t.Start()
    End Sub
End Class
Class UpdateTruck
            UpdateTruck.Close()
        End If
    End Sub
        dGPS_Info(0) = -1
        dGPS_Info(1) = -1
        dGPS_Info(2) = -1
        dGPS_Info(3) = -1
        dGPS_Info(4) = -1
        Dim dLat As Double
        Dim dLong As Double
                '4   N(North / South)
                '6   W(East / West)
                '10  004.2      Variation
                '11  W(East / West)
                '12  *70        checksum
                        dLat = -1 * dLat
                    End If
                        dLong = -1 * dLong
                    End If
                    dGPS_Info(0) = dLat
                End If
                Exit For
            End If
        Next
        ' Close everything.
        stream.Close()
        client.Close()
Exit_Here:
        Return dGPS_Info
        Exit Function
Err_Control:
            Case Else
                Resume Exit_Here
        End Select
    End Function
        Return strReturn
    End Function
        Return dtReturn
    End Function
End Class
