Author Topic: close a drawing that is not current  (Read 4266 times)
paul_s
« on: January 07, 2009, 11:07:07 AM »
Hello,
I've search this site but could'nt find a lisp routine to close an open drawing.
Close with save, and without saving. I know which drawing name to close.
Maybe something like...
(CloseAndSaveDwg "c:\\temp\\test.dwg")
(CloseDontSaveDwg "c:\\temp\\test.dwg")
Thank you in advance.
Re: close a drawing that is not current
« Reply #1 on: January 07, 2009, 11:44:22 AM »
Once you get the document object, then use the Close method of said document with correct argument for the Save argument of the method.  Since you know the name, then you can get the document object from the Document Collection.  If it is found, then close it.
Its early for me, so something along the lines of ( code written here, and no testing ):
(defun CloseAndSave ( dwgName bSave )
    (vlax-for i (vla-get-Documents (vlax-get-Acad-Object))
        (if (= (strcase dwgName) (strcase (vla-get-Name i)))
                (and
                    bSave
                    (equal (vla-get-ReadOnly i) :vlax-false)
                (vla-Close i :vlax-true)
                (vla-Close i :vlax-false)
« Reply #2 on: January 07, 2009, 12:03:33 PM »
Try this
;;;   Copyright ©2009 by K.E. Blackie
;;;   http://www.resourcecad.com
;;;   kblackie@resourcecad.com
;;;   AutoCAD 2000+  VisualLISP
;;;   USAGE
;;;   (CloseDontSaveDwg "filename with path")
;;;   (CloseAndSaveDwg "filename with path")
;;;   (CloseDwg "filename with path" :vlax-true || :vlax-false)
;;; main function
(defun CloseDwg (filename save)
  (setq acad (vlax-get-acad-object)
docs (vla-get-documents acad)
  (vlax-for doc docs
    (if (= filename (vlax-get-property doc 'fullname))
      (vla-close doc save)
;;; close drawing don't save
(defun CloseDontSaveDwg (filename)
  (CloseDwg filename :vlax-false)
;;; close drawing and save
(defun CloseAndSaveDwg (filename)
  (CloseDwg filename :vlax-true)
paul_s
« Reply #3 on: January 07, 2009, 12:23:58 PM »
Hi Tim & Keith,
Thank you guys. I love this site!
paul_s
« Reply #4 on: January 07, 2009, 12:41:41 PM »
One more thing if possible. I sometimes need to open drawings (in a read-only mode) that was already
opened by another person in the network to check or grabbed things (wblock).
Can the code be updated to close (of course without saving) a read-only that I opened but is not my current?
« Reply #5 on: January 07, 2009, 12:45:51 PM »
I believe Tim's code does that
« Reply #6 on: January 07, 2009, 12:47:42 PM »
Both codes have that ability already.  You can use the ' CloseDontSaveDwg ' routine within Keith's post.  Mine will do it without anything else needed.
paul_s
« Reply #7 on: January 07, 2009, 01:10:28 PM »
Tim,
I tried Keith's "CloseDontSaveDwg" for a ready-only drawing but it did not work. It worked fine
with non read-only files.
In your code what would be the second argument be (bSave)?
...(CloseAndSave "c:\\temp\\test.dwg" ? )
« Reply #8 on: January 07, 2009, 01:52:08 PM »
In mine it will be either ' T ' ( or any no nil value ) for save or ' nil ' for no save.
paul_s
« Reply #9 on: January 07, 2009, 02:41:46 PM »
Hmmm. It did not work. Even though the first guy closed out the drawing.
Anyway, thank you again guys.
« Reply #10 on: January 07, 2009, 03:17:11 PM »
If you have it open as read only in your session, then mine will close it without saving no matter what argument you pass it.
cadmoogle
« Reply #11 on: January 07, 2009, 03:37:36 PM »
Don't laugh at my code mangling skills  8-)
;;Close all drawing without saving
;;Original code by someone on Autodesk forums
;;Modified by cadmoogle to 'Close last drawing'
(defun doc:CloseAllButActive (TrueOrFalse / cnt)
(setq cnt 0)
(vlax-for Item (vla-get-Documents (vlax-get-acad-object))
(if (= (vla-get-Active Item) :vlax-False)
(vla-close Item TrueOrFalse)
(setq cnt (1+ cnt))
cnt
); end defun
(defun close (/) ;added by cadmoogle to close the last drawing without saving
(command "close" "Y")
); end defun
(defun c:cad ( / cnt) ;Closes all drawings except active
(setq cnt (doc:CloseAllButActive :vlax-False))
(if (> cnt 0)
(princ (strcat "\n(" (itoa cnt) ") document" (if (> cnt 1) "s" "") "
closed without saving."))
(princ "\nNo other documents to close.")
(close)
); end defun
(setq cnt 0)
(setq cnt (1+ cnt))
cnt
(defun c:cns ( / cnt) ;CLOSES WITH NO SAVE ALL DOCUMENTS EXCEPT THE ACTIVE
(if (> cnt 0)
(princ "\nNo documents to close.")
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #12 on: January 07, 2009, 04:54:24 PM »
It would be really nice if you would format the code before posting it.
some people won't even bother to try to read what you've posted.
... but please don't stop posting :)
Called Kerry in my other life
I live at UTC + 13.00
taner
« Reply #13 on: February 06, 2009, 07:38:30 PM »
                (and
                    bSave
The above code can not colse the active drawing.
« Reply #14 on: February 09, 2009, 12:02:53 PM »
                (and
                    bSave
Nope.  You might have to pass a VBA statement because you don't do it with Lisp.
