Author Topic: Stylecop  (Read 2856 times)
It's Alive!
  • Retired
  • AKA Daniel
Stylecop
« on: January 04, 2009, 11:57:01 PM »
It's Alive!
  • Retired
  • AKA Daniel
Re: Stylecop
« Reply #1 on: January 05, 2009, 01:12:10 AM »
A little weird how it wants the using directives inside the namespace curlys
i.e
// <copyright file="RbIo.cs" company="DWM Cabinet Drawings LLC">
// Copyright (c) 2008 All Rights Reserved </copyright>
// <author>Daniel Marcotte</author>
// <email>Danielm103@gmail.com</email>
// <date>2008-01-04</date>
// <summary>Contains Code</summary>
// some code is from http://blogs.msdn.com/bclteam/archive/2005/06/15/429542.aspx
namespace AcIo
  using System;
  using System.IO;
  using System.IO.Compression;
  /// <summary>
  /// Contains static methods for converting
  /// a file to a Resultbuffer and back
  /// </summary>
  public class RbIo
    /// <summary>
    /// Converts a file to a ResultBuffer
    /// </summary>
    /// <param name="path">String: Path to file</param>
    /// <param name="compress">Bool: use compression</param>
    /// <returns>a new ResultBuffer</returns>
    public static ResultBuffer FileToResultBuffer(string path, bool compress)
      if (!File.Exists(path))
        throw new ArgumentException("File Does not Exist", "path");
      ResultBuffer buf = new ResultBuffer();
      using (FileStream fs = File.OpenRead(path))
        using (MemoryStream ms = new MemoryStream())
          if (compress)
            Compress(fs, ms);
            StreamToResultBuffer(ms, buf);
          else
            StreamToResultBuffer(fs, buf);
        fs.Close();
      return buf;
    /// <summary>
    /// Coverts a ResultBuffer to a file
    /// </summary>
    /// <param name="buf">ResultBuffer: buffer to convert</param>
    /// <param name="path">String: File path</param>
    /// <param name="decompress">Bool: decompress</param>
    public static void ResultBufferToFile(ResultBuffer buf, string path, bool decompress)
      if (buf == null)
        throw new ArgumentNullException("ResultBuffer buffer");
      using (FileStream fs = new FileStream(path, FileMode.Create))
          if (decompress)
            ResultBufferToStream(buf, ms);
            Decompress(ms, fs);
          else
            ResultBufferToStream(buf, fs);
        fs.Close();
    /// <summary>
    /// Converts a resulf buffer to a stream
    /// </summary>
    /// <param name="destination">destination stream</param>
    /// Close the stream when you are done
    public static void ResultBufferToStream(ResultBuffer buf, Stream destination)
      if (buf == null)
      BinaryWriter br = new BinaryWriter(destination);
      br.BaseStream.Position = 0;
      foreach (TypedValue t in buf)
        br.Write((byte[])t.Value);
    /// <summary>
    /// Converts a Stream to a ResultBuffer
    /// </summary>
    /// <param name="source">Stream: Stream to convert</param>
    /// <param name="buf">ResultBuffer: destination buffer</param>
    public static void StreamToResultBuffer(Stream source, ResultBuffer buf)
      BinaryReader br = new BinaryReader(source);
      while (source.Position < br.BaseStream.Length)
        if ((br.BaseStream.Length - br.BaseStream.Position) > 127)
          buf.Add(new TypedValue((short)DxfCode.BinaryChunk, br.ReadBytes(127)));
        else
              br.ReadBytes(Convert.ToInt32(br.BaseStream.Length - br.BaseStream.Position))));
    /// <summary>
    /// Compress stream
    /// </summary>
    /// <param name="source">Stream: source</param>
    /// <param name="destination">Stream: destination</param>
    public static void Compress(Stream source, Stream destination)
      using (GZipStream output = new GZipStream(destination, CompressionMode.Compress, true))
        Pump(source, output);
    /// <summary>
    /// Decompress Stream
    /// </summary>
    public static void Decompress(Stream source, Stream destination)
      using (GZipStream input = new GZipStream(source, CompressionMode.Decompress))
        Pump(input, destination);
    /// <summary>
    /// Helper function for Compress and Decompress
    /// </summary>
    /// <param name="input">Stream: input</param>
    /// <param name="output">Stream: output</param>
    private static void Pump(Stream input, Stream output)
      byte[] bytes = new byte[4096];
      int n;
      while ((n = input.Read(bytes, 0, bytes.Length)) != 0)
        output.Write(bytes, 0, n);
Re: Stylecop
« Reply #2 on: January 05, 2009, 03:58:59 AM »
Haven't tried the 'cop. Probably will when I sart writing code again :)
I've seen the using statements included in the namespace scope previously. My thought was that it makes the code a little more transportable .. and the using statement is for the compiler anyway ( well, effectively ) , so I don't see an issue.
It's Alive!
  • Retired
  • AKA Daniel
Re: Stylecop
« Reply #3 on: January 05, 2009, 09:03:44 AM »
I guess my biggest complaint would be the change, I already have tons of code that’s not compliant.
It also makes attributes before the namespace a little verbose (see sample). It seems like a great tool though.  8-)
// <copyright file="Commands.cs" company="DWM Cabinet Drawings LLC">
// <summary>Contains Sample Commands</summary>
[assembly: Autodesk.AutoCAD.Runtime.CommandClass(typeof(AcIo.Commands))] //<<<<----
namespace AcIo
  using AcAp = Autodesk.AutoCAD.ApplicationServices;
  /// <summary>
  /// Test Commands
  /// </summary>
  public class Commands
    /// <summary>
    /// Test Command
    /// </summary>
    [CommandMethod("doit")]
    public static void Doit()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      try
        // 5619 packets
        // 15836 packets
        bool compress = true;
        ResultBuffer buf = RbIo.FileToResultBuffer(@"c:\Northwind.mdb", compress);
        ed.WriteMessage("\n{0} packets", buf.AsArray().Length);
        RbIo.ResultBufferToFile(buf, @"c:\Northwind.zip", false);
      catch (System.Exception ex)
        ed.WriteMessage("\n{0}\n{1}", ex.Message, ex.StackTrace);
Spike Wilbury
Re: Stylecop
« Reply #4 on: January 05, 2009, 11:07:47 AM »
<out of scope question from a c# noob per say>
    /// <summary>
    /// </summary>
Have not used, the above on any of my c# code so far, but wonder what do you pros do or use to get that ?
(I need to write a small c# app, and maybe it is time to do it right - I guess)
<end of out of scope question from a c# noob per say>
« Last Edit: January 05, 2009, 11:20:34 AM by LE »
sinc
Re: Stylecop
« Reply #5 on: January 05, 2009, 03:42:46 PM »
    /// <summary>
    /// </summary>
Before a class or method, type three backslashes.
The benefit is that these comments can be used to create auto-generated documentation.  Also, when you hover over a reference to your method, Intellisense will display the comment in the "summary" tags.
It's Alive!
  • Retired
  • AKA Daniel
Re: Stylecop
« Reply #6 on: January 05, 2009, 03:45:18 PM »
VS does some of the work when typing ///
The rest is by hand,
This is how it looks when processed by Sandcastle
Glenn R
Re: Stylecop
« Reply #7 on: January 12, 2009, 11:53:15 AM »
Yeah, I've looked at it and I liked it, so I try to follow its suggestions.
