Author Topic: Properties Dlg Box  (Read 2599 times)
Scott
Properties Dlg Box
« on: October 04, 2004, 03:43:48 PM »
Can someone please tell me why the properties dlg box pops up when I type "change" in the command line?  It has never done this before, and I don't know why it does it now.  I used to get other options when I typed "change" anyone know if there is a system setting that is messed up?
Thanks in advance
Scott
M-dub
Properties Dlg Box
« Reply #1 on: October 04, 2004, 03:52:49 PM »
Have you upgraded your AutoCAD recently?
Scott
Properties Dlg Box
« Reply #2 on: October 05, 2004, 07:31:55 PM »
Nope
Andrea
Properties Dlg Box
« Reply #3 on: October 08, 2004, 08:43:41 AM »
try -change
Keep smile...
CADaver
Properties Dlg Box
« Reply #4 on: October 08, 2004, 09:29:40 AM »
prefix the command with a "dot" as in .change
If that works, someone has redefined the CHANGE command.
Scott
Properties Dlg Box
« Reply #5 on: October 08, 2004, 01:42:49 PM »
Okay the -change and .change both work like I'm used to.  So how do I change it back?
Scott
Properties Dlg Box
« Reply #6 on: October 08, 2004, 02:43:50 PM »
REDEFINE
Restores AutoCAD internal commands overridden by UNDEFINE
Command line: redefine
Enter command name:  Enter the name of an AutoCAD command turned off by the UNDEFINE command
If a command has been undefined, you can still use it if you precede the command name with a period.
SEE ALSO
See "Redefining AutoCAD Commands" in chapter 8, "AutoLISP Basics," in the Visual LISP Developer's Guide.
Chapter 8
Using AutoLISP, external commands, and the alias feature, you can define
your own AutoCAD commands. You can use the UNDEFINE command to
redefine a built-in AutoCAD command with a user-defined command of the
same name. To restore the built-in definition of a command, use the REDEFINE
command. The UNDEFINE command is in effect for the current editing
session only.
Scott
Properties Dlg Box
« Reply #7 on: October 08, 2004, 03:18:53 PM »
That did the trick, thank CAB
