Author Topic: DIMENSION MESS IN DRAWING  (Read 5672 times)
Re: DIMENSION MESS IN DRAWING
« Reply #15 on: October 11, 2004, 06:12:06 PM »
Quote from: SDETERS
Also when I move my crosshairs across this drawing the cross hairs are very jumpy.
Try Pressing the F9 key, does the cursor smooth out?
whdjr
« Reply #16 on: October 12, 2004, 08:07:37 AM »
The jumpiness could be caused if the snap is on and set to a small increment.
my 2c
Edit: Uggghhh!! Dang CAB!! You beat me to it.
« Reply #17 on: October 12, 2004, 08:09:43 AM »
Wow, it echoes in here.
whdjr
« Reply #18 on: October 12, 2004, 08:12:37 AM »
 :D
 :D
 :D
hmmm!
Is this deja veu
 :wink:
SDETERS
« Reply #19 on: October 12, 2004, 08:29:28 AM »
Please save before opening this file
I am going to post a dwg file to the Lilly pond.  Please look at this file.  It is a cut and paste from the original bigger file.  Please window the enities to show all the grips.  Then try to move a dimension using the grips on the dimension.
I think you will see what I am talking about after you look at the file.
http://theswamp.org/lilly_pond/dimension_mess/dimension_mess.dwg?nossi=1
ImaJayhawk
« Reply #20 on: October 12, 2004, 10:33:54 AM »
Works fine after the tolerences are deleted.
--ImaJayhawk
SDETERS
« Reply #21 on: October 12, 2004, 02:03:25 PM »
I do not want to delete over 100 FCS blocks in this drawing.  But if that is what I have to do so be it.
Thanks for all of your help
Jassper
« Reply #22 on: October 12, 2004, 04:19:18 PM »
Is this something that is just in Mechanical Desktop?
I opened it in Vanilla 2004 and can play with all the dimension grips; no problems.
What do you have set up for your grips in Options, Selections....
Could that make a difference?
Sorry I can't recreate it.
Little
SDETERS
« Reply #23 on: October 12, 2004, 06:06:04 PM »
No we do not have mechanical desktop here.
Autocad 2004 is the same program I am using.
So it works ok when you try to grip and slide the dimensions around?
How about the goemetry?  Can you stretch or move that around?
I am running out of options
My grips option are set as
enable grips toggled on
enable grips tips toggled on
enable grips within blocks off
Every once in a while I get an API error.
Jassper
« Reply #24 on: October 14, 2004, 10:41:42 AM »
Quote from: SDETERS
Yeah no problems, I can do the text, node or dim lines
Yeah I have stretched most everything on the drawing
Toggled On
Toggled On
Toggled On
Object Selection Limit for display of Grips
100
Hope this helps
Little
ImaJayhawk
« Reply #25 on: October 14, 2004, 12:53:54 PM »
ImaJayhawk
« Reply #26 on: October 14, 2004, 12:55:16 PM »
Of course now that I got that error I can move stuff around    :shock:
--ImaJayhawk
ImaJayhawk
« Reply #27 on: October 14, 2004, 01:25:51 PM »
Ok here is what worked for me.
1.  Select all you tolerences using qselect
2.  Change the Dim Scale Overall from 0 to 1 in your properties dialog box.
--ImaJayhawk
 :D
SDETERS
« Reply #28 on: October 15, 2004, 08:11:46 AM »
What is this API error?  What does it mean? THat is the same error I get.  I am glad you can reproduce this problem.  Thanks for the Info
I will try your suggestion and see how it works.
Thanks again
