Author Topic: break at point question  (Read 5410 times)
ELOQUINTET
« on: September 29, 2004, 04:03:29 PM »
just out of curiousity, when i use the break at point command it works fine but if i hit enter to do it again it screws up the line like this:
 line 1    |   gap  line 2
   ______|   _________
forgive the crude drawing :oops:
ELOQUINTET
« Reply #1 on: September 29, 2004, 04:04:53 PM »
ah not what my screen showed basically it doesn't break it clean it puts a gap on one side
Dommy2Hotty
« Reply #2 on: September 29, 2004, 04:08:36 PM »
Not that this is what you're looking for, but here's the Menu Macro I made...I could change it to a LISP for ya if you wanted, so that you could hit "ENTER" to re-initiate it.
[Break @ Selected Point]^C^C^C^P(setq ent(entsel "Select Object to Break...")) \(setq pt(getpoint "Select Break Point...")) \break;!ent;f;!pt;!pt;^P
Kate M
« Reply #3 on: September 29, 2004, 04:41:10 PM »
I think that's just how macros work -- you can't re-initiate "break at point" without hitting the button again.
Dommy, a lisp would be cool, though. :-)
CADaver
Re: break at point question
« Reply #4 on: September 29, 2004, 04:48:59 PM »
Quote from: eloquintet
 line 1    |   gap  line 2
   ______|   _________
The macro issues the BREAK command and fills in the second point for you.  When you hit the enter key it just repeats the BREAK command.  You'll need a lisp function for it to repeat ant the enter key.
whdjr
« Reply #5 on: September 29, 2004, 04:52:52 PM »
Here's a lisp I wrote to do just that:
(defun c:bk (/ ent)
  (command "break"
  (setq ent (entsel "\nPick point to break Object:  "))
  (cadr ent)
Try it you might like it.
Dommy2Hotty
« Reply #6 on: September 29, 2004, 04:56:47 PM »
Quote from: Kate M
Download BAP.LSP
;;                  BAP.lsp                     *
;;           Break At selected Point            *
;;          Created by Dominic Cesare           *
;;             Dommy2Hotty@aol.com              *
;;                 09.29.2004                   *
(prompt "\nType BAP to run.....")
;;Start of Routine     *
(defun c:BAP (/ oldecho ent pt)
  ;error trapping
  (setq temperr *error*)
  (setq *error* trap1)
  ;current variables
  (setq oldecho (getvar "cmdecho"))
  ;turning off echo
  (setvar "cmdecho" 0)
  ;setting undo beginning
  (command "undo" "begin")
  ;user supplied information
  (setq ent (entsel "Select Object to Break....."))
  (setq pt (getpoint "Select Break Point....."))
  ;break command using user information
  (command "break" ent "f" pt pt)
  ;error trapping
  (setq *error* temperr)
  ;setting undo end
  (command "undo" "end")
  ;resetting echo
  (setvar "cmdecho" oldecho)
;defining error trapping
(defun trap1 (errmsg)
  (command "u")
  (prompt "Resetting System Variables...")
;;End of Routine       *
ELOQUINTET
« Reply #7 on: September 30, 2004, 11:22:41 AM »
ah i had forgotten i's posted this question so busy yesterday. works great dommy just what the doctor ordered thanks a bunch that's goin in my nostromo 52  :wink:
Dommy2Hotty
« Reply #8 on: September 30, 2004, 11:25:11 AM »
No problem...nothing fancy at all, really...
ELOQUINTET
« Reply #9 on: September 30, 2004, 11:34:17 AM »
K.I.S.S.
keep it simple stoopid  :P
Dommy2Hotty
« Reply #10 on: September 30, 2004, 11:46:32 AM »
K.I.S.S.
 :lol: Changed the order in the LISP...set the echo back too soon...so all you'll see now (if you re-download it) would be the prompts for the line and the point...
« Reply #11 on: September 30, 2004, 01:46:50 PM »
Here is another simple one.
(defun C:BRAT(/ user)
  ;(setvar "CMDECHO" 0)
  (setq user (getvar "OSMODE"))
  (command "OSNAP" "int")
  (command "_.BREAK" pause "F" pause "@")
  (setvar "OSMODE" user)
  ;( setvar "CMDECHO" 1)
whdjr
« Reply #12 on: September 30, 2004, 03:56:29 PM »
Quote from: CAB
Wasn't mine simple enough????
Quote from: whdjr
Code:
(defun c:bk (/ ent)
  (command "break"
      (cadr ent)
PDJ
« Reply #13 on: September 30, 2004, 07:16:56 PM »
OK CAB, that's SCARY!!  Here's the code I use:
(defun C:BRAT()
  (command "BREAK" pause "F" pause "@")
Great minds think alike I reckon..
« Reply #14 on: September 30, 2004, 09:53:41 PM »
Quote from: PDJ
(defun C:BRAT()
Paul,
Did we steal it from the same place? :)  Or maybe I stole yours. :D
